DJI Paladin
Hi Steph Dums, thank you for reaching DJI Forum regarding the inquiry. Please be advised that you will be needing to have the drone with you, in order to check the serial number on the battery compartment or when we set it up and to check on the DJI Go 4 app. If in case you don't have the drone with you, you may kindly check the original box as this also have the serial number information of the unit, thank you. |
