MAVIC AIR MAIN CONTROLLER DATA ERROR
4656 3 2021-5-16
sayedbayom
Flight distance : 18747 ft
I have a Mavic Air and it was working fine but suddenly I tried to connect it with my phone to fly I find the messages on the top left  MAIN CONTROLLER DATA ERROR
and I can't make calibrate please let me know what is wrong what happed to my Mavic !!
2021-5-16
DJI Stephen
Hello there sayedbayom. I am sorry to read and to know that you are having issues with your DJI Mavic Air and thank you for reaching out. Would it be possible if the said DJI drone experienced any hard landing or a crash before? You may try to refresh the firmware of your aircraft once again using the DJI Assistant 2, recalibrate the IMU and compass as well as the gimbal to see if there will be changes. The DJI Assistant 2 can be download using your computer and by clicking this link: https://www.dji.com/mavic-air/info#downloads. If the issue persists, we highly recommend contacting our DJI support team at for further evaluation of the said unit. Thank you.
2021-5-16
Spaceman_66
Flight distance : 82323 ft
Sorry, see next post...
2021-5-21
Spaceman_66
FWIW I experience this error fairly regularly in the PHX AZ area anytime ambient temps are above roughly 95F. My understanding is that is triggered by a mismatch between the onboard sensors (baro vs VPS) trying to determine your altitude At elevated temps the onboard baro reading will be off, causing the data error. So basically I have to take AZ summers off for drone-flying!
2021-5-21
