Bridge app wifi connection to assistant 2
387 0 2021-5-24
djiuser_jwEED1H9tUqt
Hello,
I have read the doumentation on the bridge app and set up everything as described, i am unable to run the simulator with my application. I know my code works as i have triggered a take off action directly to the drone (without propellors). I need to use the simulator for debugging and testing as it is too risky to perform physical tests at this stage. Can anyone give me guidance on how to use the wifi connection to bridge app and assistant 2.
heres a quick description of what im doing.
Connect controller and app to bridge (the app im connecting is in xcode simulator) the bridge app is being hosted on an ipad
Connect drone via usb to macbook pro
run assistant 2
run my xcode simulator application
attempt to execute commands - nothing happens
as far as im aware everything is connected as it should be however nothing seems to be working as it should, no activity
2021-5-24
