Cannot get Robomaster SDK working
1688 10 2021-5-26
RandomActPG
Flight distance : 19249 ft
I have been trying for days to get the SDK to install on either a Windows machine or RPi with no success.
I have followed the instructions to install on Rpi and after much struggle I got that process to work and the library to install.  I cannot, however, use it as I'm stuck with the error once I try "from robomaster install robot" line:
Traceback (most recent call last):
File "/home/admin/bottest.py", line 1, in
from robomaster import robot
File "/home/admin/.local/lib/python3.7/site-packages/robomaster/robot.py", line 31, in
from . import camera
File "/home/admin/.local/lib/python3.7/site-packages/robomaster/camera.py", line 25, in
from . import media
File "/home/admin/.local/lib/python3.7/site-packages/robomaster/media.py", line 21, in
import libmedia_codec
ModuleNotFoundError: No module named 'libmedia_codec'
Any suggestions on getting that libmedia_codec to install.  I can see it's in the git repo but I can't get the build and install to work.
2021-5-26
DJI Stephen
Super Moderator
Hello there RandomActPG. I am sorry for the trouble this has caused and thank you for reaching out. For SDK issue and inquiries, it is recommended to contact our DJI development team at dev@dji.com . The team will be able to assists and help you with regards to this matter. Thank you.
2021-5-26
CLMav
Flight distance : 424570 ft
Singapore
Which version of Python did you install? The RM SDK is not compatible with the latest version (i.e. 3.9.x) of Python. It will only work with Python ver 3.8.x or below.
2021-6-19
BGA
Did you follow this?
https://robomaster-dev.readthedo ... code_env_setup.html
2021-6-22
Alvara74
I don't know, sorry
2021-7-3
Alvara74
DJI Stephen Posted at 5-26 20:02
Hello there RandomActPG. I am sorry for the trouble this has caused and thank you for reaching out. For SDK issue and inquiries, it is recommended to contact our DJI development team at  . The team will be able to assists and help you with regards to this matter. Thank you.
Yeah, I think contacting DJI Support would be a good option
2021-7-3
Alvara74
CLMav Posted at 6-19 05:34
It doesn't make sense why its not compatible with the latest version...
2021-7-3
Alvara74
BGA Posted at 6-22 12:16
https://robomaster-dev.readthedocs.io/en/latest/code_env_setup.html
Try following this setup code, it might be able to help
2021-7-3
DJI Stephen
Super Moderator
Alvara74 Posted at 7-3 07:53
Hi there Alvara74. Thank you for the reply and for this information you have given. Thank you for your support and have a nice day. .
2021-7-5
Alvara74
DJI Stephen Posted at 7-5 20:33
No worries and thank you. I wish a good day to you too!
2021-7-5
DJI Stephen
Super Moderator
Alvara74 Posted at 7-5 22:41
Hi there Alvara74. Thank you for the reply and you are very much welcome. Again, thank you for your support and please stay safe always. .
2021-7-7
