Zenmuse Z15-A7 for new Sony A7RII
123Next >
24308 100 2015-7-20
wolfexe.inbox
Russia
neil@skypower.c Posted at 2016-1-22 08:20
Ha, I don't blame you for staying indoors if it's that cold.
Sorry another couple of questions:
1. It is easy to remove the IR port . It was glued on the scotch tape.
2. No problem.
You need to hang the weight on the lens for balancing the axis of the PITCH
2016-1-21
wima
Flight distance : 449449 ft
Switzerland
I just want to subscribe this thread, because I'm interested in a Z15 for A7RII too. But I don't know, how I can subscribe this thread...
2016-1-23
neil
Flight distance : 4814482 ft
wolfexe.inbox Posted at 2016-1-22 04:20
2. No problem.
Hi Wolf,
Just got my Z15 and trying to fit everything in.
Got the roll balanced ok, but can't seem to get the tilt to balance out.
Can you tell me what you did? I've got the camera body as far forward as I can but its still back heavy.
2016-1-25
Wolfexe
Russia
neil@skypower.c Posted at 2016-1-26 02:16
Hi Wolf,
Hi, I will write when coming home.
2016-1-25
neil
Wolfexe Posted at 2016-1-26 04:15
Great
Also, did you cut the shutter lead and make it longer?
2016-1-26
Wolfexe
Russia
Hi Wolf,
Balancing the pitch axis:
I have used mastic Bostik  Blue Blu Tac and nuts to increase the weight of the lens
Also you can install ND or UV filter for weight in combination with mastic
I have got the perfect balancing
The video:
2016-1-26
Wolfexe
Russia
neil@skypower.c Posted at 2016-1-26 21:06
Great
I didn't understand the question. Explain  in other words,please
2016-1-26
neil
Wolfexe Posted at 2016-1-26 16:01
I have used mastic Bostik  Blue Blu Tac and nuts to increase the weight  ...
Thanks Wolf for all the images.
In the end i used some adhesive weights on the front of the gimbal.
Did you lengthen your shutter cable too?
Again thanks for all the help and your time....
just need a nice day to test it all now - its currently 45mph!!
2016-1-26
neil
Wolfexe Posted at 2016-1-26 16:11
The shutter cable is very short and needs to be put in a different place. Did you make it longer so you can point it at the camera?
2016-1-26
Wolfexe
Russia
neil@skypower.c Posted at 2016-1-27 00:11
In the end i used some adhesive weights on the front of the gimbal ...
А great solution
"Did you lengthen your shutter cable too?" Yes, I did.
2016-1-26
neil
Wolfexe Posted at 2016-1-26 16:17
А great solution
I haven't yet, but just about to get the soldering iron out
2016-1-26
Wolfexe
Russia
neil@skypower.c Posted at 2016-1-27 00:26
Good Luck!!
2016-1-26
Wolfexe
Russia
Hi, I suggest to add in the thread title "...and Sony A7S II"
2016-1-26
neil
Wolfexe Posted at 2016-1-26 16:37
Hi Wolfexe,
I've just been out and flown with not great results.
In video i'm getting small vibrations in the image. Not 100% sure why as my GH4 is fine so i don't think its coming from the copter.. Something for me to look into...
And this is very strange, but sat on the ground the shutter control works every time. Once up in the air it only fires once in every 10 attempts.
Fingers crossed yours is ok.
2016-1-28
Wolfexe
Russia
neil@skypower.c Posted at 2016-1-29 01:17
Hi Wolfexe,
1. Check the balancing gimbal
2. Where to place IR ? Try to close it from the sun (from the front).  If the camera is pointed straight, with auto focus mode is not the photographing. Only with manual focus.
3. On the street again cold, -28С, really want to fly.
4. Show video of the flight please.
2016-1-28
neil
Wolfexe Posted at 2016-1-29 06:21
2. Where to place IR ? Try to close it from the sun (from the front) ...
Hi,
Here is a clip from the flight. its not the best at seeing the vibrations, but when the camera is still you can just see it better. Its in 4k so you can make it out better..
I was wondering if it may be due to SteadyShot being enabled?
AND yes i know the focus is soft - my fault!!
I've looked at the IR and it seems that light getting on the sensor is effecting it. If i block the light on it it fires ok. Just need to test in the air now when the wind stops.
2016-1-29
wolfexe.inbox
Russia
neil@skypower.c Posted at 2016-1-30 02:41
Hi,
Here is a clip from the flight. its not the best at seeing the vibrations, but when the camer ...
Hi,
DJI S900, DJI Zenmuse Z15-A7, Sony A7SII - test flight
temperature= -2С
wind= 4 m/s
steady shot - off
and with software stabilization
2016-2-7
vfrailing
Flight distance : 2564442 ft
DJI Candice Posted at 2015-7-29 06:53
Thanks for your suggestions. I would forward your suggestion to DJI R&D.
Candice, any news about Zenmuse adapting to A7rii yet?  I believe there is a lot of interest in such a product.
2016-2-7
neil
wolfexe.inbox Posted at 2016-2-7 09:09
Hi,
temperature= -2С
Looking good.
Mine is has small vibrations which is strange as its 100% balanced.
Which rubber dampness do you have on your S900 - Black or Grey?
2016-2-8
wolfexe.inbox
Russia
neil@skypower.c Posted at 2016-2-8 17:38
Looking good.
The rubber dampers - soft black (kit with S900).
I think a little freeze dampers.  Additionally I will try to install Anti-drop kit to avoid side-shift
2016-2-8
gerardo
Argentina
Wolfexe Posted at 2016-1-10 12:42
Sony A7S ii on Zenmuse Z15-A7, no problem
Hello Wolfexe. According to B&H dimension specs A7SII vs. A7S: they are different.
1-Did you do any modification to the Zenmuse? (else calibration)
2-Everything fits ok? Shutter? Hdmi? etc
3-Is The Footage perfectly smooth with the gimbal/camera combo?
4-What lens did you use?
THANK YOU VERY MUCH!!!
2016-2-10
wolfexe.inbox
Russia
gerardo@kinobov Posted at 2016-2-11 00:33
1-Did you do an ...
HI,
1. To read post 41.  You need to move the IR sensor. Additionally need a microhdmi adapter and microhdmi cable. The adapter is needed to connect two micro HDMI wire, because the gimbal mini HDMI cable is short (the micro HDMI port on Sony A7S II turned to the other side).
2. Yes.
3. Yes, as with A7S
4. Sony FE 35 mm f2.8 ZA (standard for gimbal)
2016-2-10
info.andrewgreg
wolfexe.inbox Posted at 2016-2-11 12:17
HI,
1. To read post 41.  You need to move the IR sensor. Additionally need a microhdmi adapter and  ...
Hi,
Is anyone having trouble with shooting stills on the A7r2. After I shoot a still my monitor freezes, it doesn't happen with video.
Also I can only get it to shoot a still frame while it is pointing straight ahead in manual or release priority mode. Point the gimbal down a bit and the shutter fires.
None of these issues on the a7r
2016-2-11
cornel
Flight distance : 62736 ft
Romania
info.andrewgreg Posted at 2016-2-12 06:50
Hi,
Is anyone having trouble with shooting stills on the A7r2. After I shoot a still my monitor fr ...
Yes, I am having the exact same issue!
The REC function works in any position, but the PHOTO doesn't work when the camera is oriented to the front, only downwards.
I looked with another camera at the IR sensor and it works in any position, so the problem comes from the camera.
There must be a setting or something that's not ok, but I cannot figure out which one... Can anyone help?
2016-2-16
neil
cornel@sierra.r Posted at 2016-2-16 09:02
The REC function works in any position, but the PHOTO doesn ...
I had issues with the shutter on my A7Rii. It would seem like the daylight/ sunlight is effecting the IR.
I made this cover for mine and it fires every time now.
2016-2-16
neil
info.andrewgreg Posted at 2016-2-12 04:50
Hi,
How is the quality of your video?
Do you have any jello or vibration?
I have a very small amount and can't seem to get rid of it. The odd thing is its fine with my GH4 + Z15.
2016-2-16
cornel
Romania
cornel@sierra.r Posted at 2016-2-16 11:02
Yep, the problem with the shutter that goes on only when the camera faces down was because of light kept interfering with the IR.
You do need to protect the IR from light.
2016-2-17
flycam24
Russia
I do not understand what the problem is. Everything has changed, and did as they said at the forum, but I have a bad picture is recorded
I use S1000 with Z-15a7s  camera sony a7sll
2016-3-3
neil
flycam24 Posted at 2016-3-3 19:02
I do not understand what the problem is. Everything has changed, and did as they said at the forum,  ...
You have the exact same problem as me with my A7rii.
Its either the gimbal can't take the extra weight or the camera is too sensitive.
I just installed my A7S (mk1) and the picture was perfect.
2016-3-4
flycam24
Russia
It was much better, but not perfect. Work continues...
2016-3-14
neil
flycam24 Posted at 2016-3-14 19:07
https://www.youtube.com/watch?v=X43DOuutM6M
Looking good!
what did you change to get it looking better?
2016-3-15
vfrailing
Wolfe, I have been reading this link for a  while, and I would like to thank you and everyone else for your contributions. Any progress of late?
I have a bunch of related questions:
Is the Sony A7Rii a viable camera for aerials?  Why has none of the companies I have checked out made a gimbal for it?  Is there something inherently impractical for it to function in this role, or am I just being impatient? Or is the best method just to adapt another gimbal?
I am trying to put together as good of a rig for doing photography, particularly stills.  I have taught photography and art for 34 years, have recently finally "graduated" from teaching.  Have had a P3P for about 6 months, have made some good images and a lot of fun, but am dissatisfied with the print quality.  Shoot RAW, and process HDR images for anything I care about, and they are ok, but once you start printing over 10 x 14 or so, the image suffers.
I purchased a A7Rii for the Zenmuse gimbal, without reading the fine print about it not fitting the mk ii.  I am thrilled with the image quality from the camera, and just want to get it up in the air to take images.
I have looked at the s1000, the s900, and the Tarot X6.
Sorry for all the questions, here is an image from the P3P...
Hope that worked
2016-3-26
flaviomjr
stewart@stewart Posted at 2015-7-21 06:53
Two more questions Dji support 8 and thank you for your time.  Is Dji working on any new zenmuse gim ...
Stewart as much as i hate to say this i wouldnt hold my breath for it. Seems like DJI main focus now is on their phatoms and inspire 1 platforms.
Unfortunately we the spreadwings owners have been pushed to the side.
2016-4-1
flycam24
Russia
After the video camera picture perfect completion
2016-4-3
carmelo0075
Flight distance : 119754 ft
hi @flycam24 can you describe how you came to that result?
tkx
2016-4-3
wolfexe.inbox
Russia
Another test after replacing the A2 IMU and vibration dampers in motors (part 35). On video it is visible that Z15-A7 works well, the problem was in the S900.
2016-5-3
carmelo0075
I do not understand why the shot does not work in af, forward mode, it only works in manual
2016-5-4
carmelo0075
hello wolfexe.inbox  can you tell me the gain you are using? thank you
2016-5-5
Wolfexe
Russia
carmelo0075@gma Posted at 2016-5-6 02:25
Hello, recommended gain 110,110,120,220,220,120. Decrease the value, I did not notice the difference.
2016-5-5
carmelo0075
umm , with wind and very unstable with these values ​​, I raised the values ​​let you know as soon as I try
2016-5-5
123Next >
