Zenmuse Z15-A7 for new Sony A7RII
123
24358 100 2015-7-20
Wolfexe
Russia
carmelo0075@gma Posted at 2016-5-6 12:30
umm , with wind and very unstable with these values ​​, I raised the values ​​let you know as so ...
I have to wind stable flies with these gain. I spend a shooting at a wind of 4-5 m / s
2016-5-6
carmelo0075
Flight distance : 119754 ft
si può provare questo
di base
Passo 145
del rullo 145
imbardata 145 Attitude passo 135 rotolo 135 verticale 140
con il tatoo 16000
2016-5-6
Wolfexe
Russia
carmelo0075@gma Posted at 2016-5-6 23:07
di base
Passo 145
I do not see any reason to raise if stable. I use maxforce 2х10000 mah battery, take off weight of 8.1 kg
2016-5-6
carmelo0075
Wolfexe Pubblicato un 2016/05/07 05:06
Non vedo alcun Motivo per Alzare sé stabile. Io uso Maxforce batteria 2х10000 mah, togliersi il peso di ...
I also fly with more wind and I need higher gain. undestand why the camera shoots horizontally with auto focus? this is important
2016-5-7
Wolfexe
Russia
carmelo0075@gma Posted at 2016-5-8 06:24
I also fly with more wind and I need higher gain. undestand why the camera shoots horizontally with ...
I shoot photos and videos in MF mode, focus to infinity. In this mode, you need to shoot from the air.
I don t know why not shoot in the AF mode is horizontal.
2016-5-7
neil
Flight distance : 4814482 ft
wolfexe.inbox Posted at 2016-5-3 16:47
Another test after replacing the A2 IMU and vibration dampers in motors (part 35). On video it is vi ...
Hi Wolf,
What was the issue with your S900 as i'm still getting issues with my A7Rii on my S900 (Wookong)
Thanks
2016-5-8
Wolfexe
Russia
neil@skypower.c Posted at 2016-5-9 06:10
Hi Wolf,
What was the issue with your S900 as i'm still getting issues with my A7Rii on my S900 ( ...
Hi, I installed the new IMU A2, calibrate it. Connect the individual motors to the controller.
2016-5-8
neil
Wolfexe Posted at 2016-5-9 05:49
I think my problem may be different in that case. I'm getting micro vibrations still. If i use my GH4 its perfect. The A7Rii is balanced in all 3 axises. Is there anything you do with the camera settings? Do you turn off the 5 axis stabilisation?
2016-5-8
Wolfexe
Russia
neil@skypower.c Posted at 2016-5-9 15:53
I think my problem may be different in that case. I'm getting micro vibrations still. If i use my  ...
The camera settings are standard, steady shot off. When the copter hanging there vibrations?
2016-5-9
agpilot2b
Flight distance : 3852293 ft
New Zealand
Hi Guys,
Been a DJI user since 2014 with the P2V+, then I1 Version 1, P3 Advanced, then I1 Pro and S1000 Premium.
I have just yesterday tweaked and got my new S1000+, A2, LB2, Z15-A7 fitted with a A7Rii working like a dream.
The A7Rii doesn't properly fit into the Z15-A7Rii properly and you have to make some adjustments the the Z15 frame to get all the balancing correct.
You also have to change the HDMI-AV cable. The BMPCC cable is that tiny bit longer than the standard cable from the Z15-A7, so that work well now.
The IR transmitter for shutter and recording control needs to be sheilded from sunlight, as the A7Rii is forced to sit a little further back due to a slightly larger handgrip on the A7Rii vs the original A7R.
All in all though, not too hard to achieve with a little bit of tinkering around.
2016-8-12
rameshtahlan
India
neil,
that is a fantastic job with the A7Rii and z15 A7 gimbal.
My friend has the same equipment, and is coming over today to get it installed by me
However, for making the camera fit, i guess you would have lowered the base or bottom plate
could you conform.
Regards
2016-9-28
rameshtahlan
India
agpilot2b@hotma Posted at 2016-8-13 04:21
Hi Guys,
Been a DJI user since 2014 with the P2V+, then I1 Version 1, P3 Advanced, then I1 Pro and  ...
Great going with the A7 gimbal and Rii.
Hopefully this week i should set up my friends system which has same setup as yours.
2016-9-28
viktor2
Czechia
Hi
We are trying to install the A7-II in the gimball.
The platform is extended to maximum even the bottom set of the upper screws.
But the camera is still can not be set even
2016-9-30
fansddc39806
Flight distance : 1699 ft
rickywood@iclou Posted at 2015-8-25 01:53
We currently have an A7s & A7R that work well on the Z15-A7 gimbal. We are going to buy a A7R MkII - any updates on the support for the gimbal?
I wish I could figure out how to get the A7R shutter to function on the A2 controller. Any help would be greatly appreciated.
2017-1-26
fansddc39806
Can you help me get the shutter to work on My Sony A7R with the Z15-A7 gimbal? I have an A2 controller. Thanks!
2017-1-26
DJI-Jamie
Flight distance : 112405 ft
fansddc39806 Posted at 2017-1-26 12:41
Just to clarify, are you using the A7R Mrk I or the Mrk II?
2017-1-26
fans102cacd6
Czechia
Hi
I'm trying to process the conversion to A7S-II as well. Modifying the gimball was not that hard. I only do have a problem with the IR port I guess. Shutter is not working when I put the camera in the gimball and it is facing horizontally (screen is not working as well). I guess this is related to camera as the behavior is same when the Z15 is witched off. Where is the IR sensor?
Thank you
Viktor
2017-7-12
fans9b983648
Hello does anybody on this forum know if the DJI s900 is compatible with the infrared camera and what gimbal?
2017-8-3
fanse28c8f82
Hello, I have the same configuration as you (S900 A7Sii) but there is still this problem of vibration on the video.
Today, did you find a solution to stop the vibrations?
2018-1-14
FloStone
Switzerland
The problems with the vibrations might come from the missing hold for the camera. The camera is most steady when attached to the gimbal on 2 spots (bottom mount screw and lens ring in front). When one support is missing or loose, then vibration ocure.
2018-2-14
james.hazou
A7Sii installed on Zenmuse Z15 gimbal. Original HDMI cable used. There is slack cable behind the gimbal base plate. To access carefully remove the base plate. Slack cable ia held in place by double-sided tape. Carefully remove the tape and extend cable. Use a little hot glue to reinfoced the connection on the circuit board. Carefully replace the backplate ensuring none of the fine HDMI cables are trapped. I then used rubber amalgam tape (it bonds to itself) as a cable shroud. Use a small drop of hot glue to seal the outside of the cable where it enters the base plate. The original HDMI cable will now be long enough to reach the camera port. Very gently bend the cable back on itself. Do this before the HDMI connector. The connector with then fit the A7Sii HDMI port. The little IR sensor is easily repositioned; it's only held in place by double-sided tape. This will allow the camera to be placed fully foward in the gimbal. A lens counter balance is required. I used the smallest car tyre self-adhesive lead balacing weight and placed one on the inside of the lense shield. It fits perfectly and cannot be seen. Lastly, fully rebalance the gimbal, leaving the yaw balancing to last.
The camera and gimbal are installed on the large 2m diameter Foxtech K130 Octocopter platform. It can be used as a single operator mode or with 2 crew. A fixed-view FPV camera gives a pilot's eye-view. Remote switching between the FPV and A7Sii cameras is achieved via the DJI iOSD.
2018-5-1
123
