Motor monitoring for failure.
370 1 2021-5-29
Ozzyjim
Hello,
I own a M600pro and it has excellent redundancy built in, however I would love to see on future inspire and other professional / enterprise series drones on board monitoring of temp, voltage draw and amp draw of its motors... I know I could buy the sensors aftermarket and write a program log it to a raspberry Pi or the manifold available through DJI, however built in systems from the factory and data available in the flight app would be great.. Reason being that a failing motor could be detected earlier and replaced before a in flight failure.. Again not an issue on the m600 so much but.....
For a bit of extra "smarts" on the motor side RPM and individual serial numbered motors could be used to log motor hours and rpm measured against volts/amps across the drone again to see if a motor has to work harder than the rest to maintain rpm..
Interested to hear other opinions..
Cheers.
2021-5-29
Mats Bohlinsson
Flight distance : 1838077 ft
Sweden
Yeah it's strange that this havn't been done.
I know at least a couple of M600 crashes that could been avoided if the temp of the esc's had been monitored.
2021-6-7
