P4 MULTISPECTRAL New Firmware Release Notes (01/06/2021)
1666 10 6-1 02:03
DJI Support
Flight distance : 2408 ft
South Africa
Overview:
  • Date: 2021.06.01
  • Aircraft Firmware: v00.00.0146
  • Remote Controller Firmware: v00.00.0146
  • DJI GS Pro App: v2.0.16
  • DJI Assistant 2 For Phantom: v2.0.10
  • DJI Terra: v3.0.1
What’s New?
  • Added numerical filtering to the multispectral sunlight sensors to solve the issue where the aircraft collected incorrect data at the turning points of a flight route.
  • Added optimal operating time recommendations for flight missions according to where and when the user is operating. To view the optimal operating time for a mission, make sure DJI GS Pro is connected to the aircraft, slide the mission to the left in the mission list, and tap Sun.*
  • Added HD map of Mainland China for a clearer map display when planning missions.*
  • Added support for eID to P4 Multispectral EU version to meet French regulations.*
  • Fixed issue: sensors reported statuses incorrectly.*
     * V2.0.16 or later of DJI GS Pro is required. Pay attention to DJI GS Pro version updates.
Notes:
  • The aircraft cannot be downgraded to v00.00.0130 after this firmware update.
  • After updating the remote controller with this firmware version, the remote controller can only be used with the P4 Multispectral aircraft.
  • Make sure that the firmware for the aircraft and remote controller is up-to-date and the firmware for the D-RTK 2 Mobile Station is v02.02.0505. Otherwise, they will not work together.
  • Using this firmware with a version of DJI Terra older than v2.1.1. is not recommended, as some functions will not work properly.
6-1 02:03
Montfrooij
Flight distance : 2133671 ft
Thanks for the info!
6-1 05:57
JetSam
Flight distance : 2489482 ft
Nice !
6-1 08:41
DJI Stephen
Super Moderator
Montfrooij Posted at 6-1 05:57
Hello there Montfrooij. Good day and thank you for the reply. Have a safe and a happy flying always. .
6-1 18:37
Montfrooij
DJI Stephen Posted at 6-1 18:37
You too!
6-1 22:45
LV_Forestry
Flight distance : 2879803 ft
Latvia
Connection to NTRIP server with GSPRO does not work since the last update.
DJI online Customer Support promises to manage to get someone from DJI Enterprise to contact me, one week ago,  but as usual with the Enterprise product ...
6-16 11:32
patiam
LV_Forestry Posted at 6-16 11:32
Just acquired a P4 Multispectral. NTRIP is a must for us. Has this been resolved?
6-17 08:02
LV_Forestry
Latvia
To date, no response from DJI, no improvement.
However I can also suspect my NTRIP provider. They will update the server on July 1st. We'll see if that fixes the problem.
Until then if someone could confirm the same failure. P4M and RC last update / Ipad (i tried some OS, same results) / NTRIP server GPS Glonass Beidou Galileo.
Disclose: the connection to NTRIP works with UGCS, so I still strongly suspect GSpro to have a problem.
6-18 05:50
patiam
Good to know. Holding off on the update for now (unless there is some must-have reason to do it). Even though I plan to go the Android UGCS route, I don't want to shut the door on iPad as a last resort, and NTRIP is an important part of our workflow in many settings.
Good luck w/ Enterprise "support"! Hang in there and keep us posted please.
6-18 08:20
djiuser_DuznuQexxe53
Salve qualcuno può darmi un aiuto?
Ho fatto un volo automatico con p4 multispectral impostando i seguenti valori:
Overlap overside 80%
Altezza di volo 30 metri
Velocità 5m/s
Shutter angle: perpendicolare.
Ho utilizzato app dji gs pro.
Una volta eseguito il volo carico le immagini in dji terra, e eseguendo la ricostruzione mi dice " ricostruzione fallita" o "gs.recostruction- 3009". Qualcuno può aiutarmi?
7-10 05:07
Velocità 5m/s
7-10 05:08
