No Single pictures on panorama
5370 24 2021-6-1
Sensei-1978
Flight distance : 157736 ft
Hello.
When i make a panorama there are no single picture on the AIR 2S. I find no options in the Fly App to activate Single picture recording when i make a panorama.
2021-6-1
DAFlys
You should have a special panorama folder with them in.
2021-6-1
Sensei-1978
DAFlys Posted at 6-1 23:51
Yes i know.  On the release of the drone there was a panorama folder on it. But since the last firmware update there a no single pictures after a panorama shooting
2021-6-2
GBerl001
Flight distance : 186781 ft
Have you tried downloading them from the app? I haven't pulled the card since the firmware update but I did just take a panorama after the firmware update and I was able to transfer to my phone using the app.
2021-6-2
Sensei-1978
I tried an older Version of the fly app. There is no problem. The newest app version is the problem.
2021-6-2
itsdavesdrone
Flight distance : 6763835 ft
Make sure you change the settings to raw+jpeg. You have to change it from the panoramic tab while the drone is connected, it has its own settings tab once you are in that mode. Once you have raw+jpeg selected it creates a separate PANO's folder inside the SD card with all the separate images you have to stitch yourself.
I have a lot of problems stitching the pano's in Lightroom if some of the shots are dark. If they are too dark, Lightroom won't stitch them. It's really annoying and happens quite often if you underexpose your shots if sun is involved etc. If anyone has any good Mac program recommendations for stitching pano's let me know!
2021-6-2
Sensei-1978
Yes but the setting are only in an older version of the fly app  there. Not on the New version.
2021-6-2
itsdavesdrone
Sensei-1978 Posted at 6-2 15:18
Oh really... it works for me with raw pano shots but I don't know if the options are there I haven't needed to use them for a long time since changing. They also removed the charge/no charge for devices button on the new app for iPhone... annoying!
2021-6-2
hallmark007
Flight distance : 12400594 ft
itsdavesdrone Posted at 6-2 14:20
The best most reliable way is to shoot manually, and merge in PS or Lr , you have much more control you can take as many photos as you please. Auto is great for quick jpegs but why go to bother of giving up control when its pretty simple and straightforward manually.
2021-6-2
jmb63
Flight distance : 7019370 ft
I just tried a little experiment to see what/where to find the setting to save the individual panorama shots,
This is a screenshot of the setting for that expanded up by touching the "Format" area while in a panorama mode. You can see how I have it set to save the originals as RAW which will save them to a separate folder
This is with the Smart Controller with the latest Android version of the Fly app.. 1.4.2 ..1.4.3 is just IOS I think?
2021-6-2
Sensei-1978
Ok i will try it. Then the picture settings are under an other location with the newer app versions. Thank you for your help. I searched the settings on the camera  menu after clicking the three points on the upper right corner.
2021-6-2
jmb63
Sensei-1978 Posted at 6-2 22:42
Yes, as I have outlined in this image, you have to have it in a panorama mode (indicated just above the shutter button) and then touch the "format" area on the lower right to get that setting...
Same as setting most other individual items now....such as the video resolution/frame rate and if in pro/manual mode, shutter, WB, ISO etc
2021-6-3
Sensei-1978
jmb63 Posted at 6-3 04:28
Thank you very much. Now all is working.
2021-6-3
Huginn Kenningar
Flight distance : 49635259 ft
You also have to wait/hover for the panorama to reach 100% before move, if you move the drone before it reaches 100% it will cancel it and the images won't be saved (or maybe it saves only a few of them, but not all).
It should save in the SD every DNG file and a blended JPG.
2021-6-3
New_Flyer
Was wondering the same thing! I just got an Air 2 S. Amazing piece of kit!
2021-6-3
New_Flyer
2021-6-3
jmb63
Sensei-1978 Posted at 6-3 05:43
You are Welcome...Enjoy!
2021-6-3
DJI Stephen
Hello there Sensei-1978.  I am sorry for the trouble this has caused before and it is great to know that you were able to sort the issue out after following the post of jmb63 on post #14. Thank you and keep flying.
2021-6-3
Mavic2018
Flight distance : 1544065 ft
Thank you for posting this as it has been wracking my brain trying to resolve it.
2021-6-4
jmb63
Mavic2018 Posted at 6-4 04:50
2021-6-4
DaanFPV
Any way to have a panorama photo a DNG file?
2021-6-4
jmb63
DaanFPV Posted at 6-4 11:36
The panoramas that are "merged/processed" automatically by the drone/app come out as JPG only.
If you want a DNG panorama, you would have to take the saved individual DNG shots and merge them in a program
2021-6-5
fansc8d59e4a
Flight distance : 32582 ft
Dominican Republic
I just have to give you guys a BIG thanks to help me solve the issue. I drove myself crazy thinking that DJI will take care of the stitching of the pictures. The Panorama stitching on the app is SOOOO bad.
I went to the Customer support page on DJI website and the person helping me did not know anything about this issue and could not provide an answer. It's like they are overseas in an office and have NEVER seen or used a drone before... That person was clueless.
Anyways, thanks to you guys!!!! You rock!
2021-6-25
Captain Dangerous
Flight distance : 251762 ft
There is a separate folder on the SD card, and i can confirm with latest firmware its still there. I think you have to have the drone set to capture JPEG+RAW to get them as the individual ones are RAW I beliieve
2021-6-25
Jeffiv.com
I'm more than proficient with Photoshop (and have created several panoramas from their respective folders, etc) but it occurs to me that it seems kinda like DJI is leaving something out, doesn't it? If they're going to provide the ability to shoot a panorama, why don't THEY provide the software (or do it automatically, as the rest of the process is automated) to ACTUALLY create the panorama? Am I the only person that feels like they kinda stopped before they were finished in this respect? What about people who aren't good with, can't afford, etc. high end post processing software like Photoshop? It really seems like a $2k+ drone should come with everything required to actually produce the end result without additional software.
2023-11-22
