SD card format
43328 12 2021-6-3
patdig
Flight distance : 443510 ft
How do I format my SD card when attached to my phone? I'm unable to locate that setting on my phone?
Do have to format card when osmo is not attached to the Phone?
2021-6-3
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. You can do format your SD card using your computer, patdig, and please note that the SD card that is less than or equal to 32GB should be formatted into the FAT32 file system while the SD card that is larger than 32GB should be formatted into exFAT file system. Also, please make sure that you back up all your files before formatting. Thank you for your support!.
2021-6-3
Curt1591
Thailand
Can't do that while attached to his phone ...
2021-6-3
Aavalaakso
Flight distance : 328 ft
Finland
There is Format SD Card in the MIMO settings.
2021-6-3
Curt1591
Thailand
Aavalaakso Posted at 6-3 22:03
He'd like to know where.
2021-6-4
Deptiy
Ukraine
I use a special adapter and format the memory card on my PC.
2021-6-4
Aavalaakso
Finland
Time: 7:35
2021-6-4
Aavalaakso
Finland
Deptiy Posted at 6-4 01:19
Always format cards using the device where card is. Many devices makes own invisible magic to the cards that PC wont recognize but may affect using the device. Even if file system is FAT32 (or what ever) you can write other information to the card.
2021-6-4
Curt1591
Thailand
Perfect answers
2021-6-4
patdig
Aavalaakso Posted at 6-4 01:58
I just wanted to know if I could format the SD from the Mimo app on my phone. I did not want to have to turn off the app on phone and then use the camera to format card.
2021-6-4
Curt1591
Thailand
patdig Posted at 6-4 13:03
Through the method in the video, the Pocket is formatting the card through the Mimo app.
2021-6-4
Deptiy
Ukraine
But don't forget to back up your files before formatting. Otherwise, you will have to use Uneraser or other software to restore them.
2021-6-9
Deptiy
Ukraine
Deptiy Posted at 6-9 03:45
As an addition to the Uneraser program, I can also recommend Easus if you need to recover deleted files on a SD card.
2021-6-22
