Vision Sensor Calibration Error on my two FPV drones
6743 10 2021-6-7
hexaborders
Flight distance : 158491 ft
Hey guys. I got two DJI drones, I have a « Vision Sensor Calibration error » on both.
I tried Compass,  IMU calibration and recalibrate it through Assistant 2 (for FPV Series) on my Mac.
I’m seeing those green dot for each sensor so I supposed they’re detected and functional.
I’m still with this error.
I was thinking about a firmware bug ...
Any ideas ?
2021-6-7
DJI Stephen
Hello there hexaborders. I am sorry to know that you are having issues in calibrating the sensors on both your DJI Drones. Please try to calibrate the said drone using a monitor display of 14 inches or bigger is recommended for the calibration. Please set the display’s resolution to the recommended default value. ( Usually, the 14-inch display’s resolution should be set at 1366*768 or 1440*900. The 17-inch display’s resolution: 1366*768 or 1280*720. The 19-inch display’s resolution: 1366*768 or 1440*900. The 22-inch display’s resolution: 1680*1050 or 1920*1080. The 24-inch display’s resolution: 1920*1080 or 1920*1200.) Thank you.
2021-6-7
hexaborders
DJI Stephen Posted at 6-7 21:29
Hey Stephen !
I only have a 13’ MacBook Pro at home..
I’ll try again but I’ve done this several times and I still have this error message
2021-6-7
hexaborders
Up !
Someone fixed the issue ??
2021-6-8
Crashin2416
Flight distance : 3638983 ft
hexaborders Posted at 6-8 09:41
Up !
What does that mean?
"Someone fixed the issue ??"
Is your Vision Sensor working correctly now?
I am in a similar boat, having a Sensor System error.
However, mine also states GPS error, as well.
2021-6-9
FlyingSnoopy
Greece
Crashin2416 Posted at 6-9 21:59
GPS error and sensor system error? That's a bad combination. Did you get the error after replacing the cover? My first drone had this error after 3 flights. The only fix is a replacement
2021-6-9
hexaborders
I just wanted to know if someone found a solution for this issue.
I connected my two DJI drones on DJI Assistant 2 and I've done the calibration process, I saw green dot and preview for each sensor (left and right) but nothing changed still this error on my goggles.
I'm trying to enable Dev Mode on DJI Assistant 2, in order to get more infos..
I'll let you know guys if I find something
2021-6-9
Crashin2416
FlyingSnoopy Posted at 6-9 22:19
Not after replacing the cover, which I have done multiple times just fine.  I swapped onto the green one after the first few flights, for increased visibility LOS, but switched back to the smoke clear one after deciding I'd rather primer and paint the green one (then bought the replacement pack [comes with both, again]), so now I can paint two green ones differently, perhaps.
I actually have over 50 flights logged on the DJI FPV
Whatever the case may be, looks like I'm going to have a good week or two to work that all out, as I've already exhausted the troubleshooting steps available, and have a DJI Care Case in action.  The drone is all packed up, minus some carton filler to secure it (I used the original foam insert, cut down to just the drone itself's part, fits VERY nicely in the bottom of a random NewBeeDrone box I happened to have handy).  I'll get it off to the local DJI service center by Friday.  There's a small chance I may get it back next week, but I figure the week following is my best bet.
2021-6-10
Franzdampf
Flight distance : 7022441 ft
Hey, i've noticed the exact same issue today "Vision sensor calibration error" on the maiden flight. It's a brand new drone. Only installed all updates, it was never in the air. Any tips on how to fix this? I can calibrate the vision system with the assistant, the Gimbal moves freely up and down. Is it a hardware issue?
2021-7-24
fans83d0313e
hexaborders Posted at 6-7 22:57
Hey Stephen !
Hello have you figured out how to fix the issue?
2021-12-27
Lnfrank Thor
Flight distance : 332116 ft
Have anyone came up with a solution? I crashed my drone and had to replace the sensors and needs to be calibrated. Everything else on the drone works and the calibration goes through but I still get same error on the goggles. Any ideas? Thanks
2022-12-28
