DEFredEricS
Hi,
I am aware that the Osmo Pocket 2 has a full lock mode, which can be triggered either by keeping the function button pressed or by using the controller wheel or extension rod add-ons - the latter not being possible when using the Pocket 2 in its accessory mount. However, there is no way to set the gimbal to permanently lock onto a specific point without activating active track. Active track automitcally centers the tracked object which is not always the desired result. Since the full lock mode is already available, why not make it accessable in the gimbal settings and allow to manually set the tilt of the gimbal as in tilt locked mode?
And that brings me to my second issue - tilt lock. This worked perfectly on my motorbike the first couple of times I used the Pocket 2. I have it mounted to my chest with the accessory mount and a Chesty. I then center the gimbal, select tilt lock and adjust the tilt to have my handlebars just at the bottom of the screen. As I said, this worked fine the first couple of uses. However now, after I've adjusted it as mentioned before, it starts moving down during the ride and then back up to the original position, kind of as if it where losing its original position and then just readjusting to somewhere else and then going back to the original position. This happens regardless of speed, acceleration, battery charge or body movement. Any tips on what to do?
Cheers,
Fred
