DJI Air Unit Range less in FCC Mode
2316 7 2021-6-11
COLDFusion
Flight distance : 279583 ft
I have a DJI Air Unit. I am in FCC Mode and can see the 8 Channels, the Option to 700mW and 50MB/s.
Manual says i should have Range to 4km. When i fly i have only Range of around 400m. I have nothing between me and plane and it is complete full open field.
What do i wrong? The Range is horrible. I know that 4km is just under perfect conditions. But sorry 400m in FCC Mode???
2021-6-11
MarcelN
Flight distance : 2307733 ft
Are the goggles also in FCC?
2021-6-11
COLDFusion
I enabled the FCC Mode in AirUnit with naco.txt file.
What should i do to put the goggles in FCC Mode?
2021-6-11
MarcelN
https://b3yond.d3vl.com I don't know if this would help, but it does for DJI's fpv drone. Or use another type of receiver besides the air unit. Look what the 'long range' guys use, mostly low frequentie gear.
2021-6-12
COLDFusion
solved.
Power Limit was wrong. I was always at 25mW even when i setup 700mW.
Now i am happy. Range is very well.
2021-6-13
MarcelN
COLDFusion Posted at 6-13 10:43
solved.
How did you found out that it was not transmitting 700mW and only 25? So in the goggles you saw 700 but it was 25?
2021-6-13
COLDFusion
https://dl.djicdn.com/downloads/ ... _User_Manual_EN.pdf
look on site 28 and then Point 11 Device. I was all the time in Low Power Mode.
You can also look at Website Website for more infos
2021-6-13
MarcelN
COLDFusion Posted at 6-13 12:25
Yes I know about these settings in 'Device', so you didn't? Glad you found it, I thought you knew about it where to find it so I didn't mentioned it.
2021-6-13
