DJI FPV Combo M-Mode question
391 6 2021-6-13
TarasFPV
Flight distance : 248268 ft
I'm wondering what would happen if dji fpv combo loses connection in m mode?
Would the drone immediately auto-balance itself? or would it take a few seconds?
2021-6-13
aem:kei
Flight distance : 1101624 ft
Austria
yes, TarasFPV, hovers in place, no matter the orientation in space at the time of LOS (eg upside-down) and depending on your settings, can also do RTH. Basically the same as if you press the stop button (plus RTH)
2021-6-13
aem:kei
Austria
2021-6-13
aem:kei
Austria
And it happens immediately, btw, just to be clear.
2021-6-13
Depp
Flight distance : 1868796 ft
No problem at all. For me it often switches to N mode when it feels it is too far away. Then I take it up a bit and a bit closer, switch back to M and all is well.
2021-6-13
frankymusik
Flight distance : 27841053 ft
aem:kei Posted at 6-13 04:50
2021-6-13
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. If the DJI FPV loses control or the goggles image transmission signal is lost when flying in Manual (M) mode (with the strong GPS signal, normal compass function, and successful recording of home points by the aircraft), the flight control system will immediately switch to Normal mode and hover. After hovering for 3.5 seconds, the aircraft will trigger auto RTH. Hope this helps. Thank you for your continued support!
2021-6-13
