DJI Mini 2 Release Notes (06/16/2021)
12345Next >
31909 162 2021-6-15
DJI Support
Flight distance : 2408 ft
Overview:
Date: 2021.06.16
Aircraft Firmware: v01.03.0000
Remote Controller firmware: v04.11.0016
DJI Fly App iOS: v1.4.3
DJI Fly App Android: v1.4.2
What’s New?
  • Added support for DJI Smart Controller (requires DJI Smart Controller v01.01.00.58 or later).
  • Optimized gimbal FPV mode to improve flying experience.
  • Optimized auto-discharge process for battery. Refer to DJI Mini 2 User Manual for more information.
  • Improved flight stability and greatly reduced quantity of compass calibration prompts.
2021-6-15
mukhas
Flight distance : 832605 ft
Ukraine
Thank you for update!
Please tell me, is there available 5,8 Ghz frequency for Ukrainian users already?
2021-6-15
Wacko_66
Flight distance : 216778 ft
Awesome! Finally!
2021-6-15
Montfrooij
Flight distance : 2500942 ft
Thanks for the news!
Looks like a nice update !
2021-6-15
DAFlys
Flight distance : 76512231 ft
Any update to the gimbal when flying at -90 degrees?
2021-6-16
DJI Stephen
Super Moderator
Montfrooij Posted at 6-15 23:45
Hello there Montfrooij. Thank you for the reply and for the positive feedback for the new DJI Mini 2 firmware update. Again, thank you for your support and have a nice day.
2021-6-16
Montfrooij
DJI Stephen Posted at 6-16 00:35
You're welcome!
And likewise!
2021-6-16
DroneJunkieQc
Flight distance : 978848 ft
Thank you this is amazing news
2021-6-16
MySky
Flight distance : 331913 ft
Hopefully the creation of the final panorama on the drone has been implemented, instead of just storing the HTML and 26 pics.
2021-6-16
NickLy
Flight distance : 86591 ft
Israel
Thanks!
Btw any updates on SDK support and/or active tracking mode?
2021-6-16
DowntownRDB
Flight distance : 525 ft
Great news.  Nice to see Mini 2 now SC capable.  Hopefully, this fixes the battery issue where it wasn't auto discharging.
2021-6-16
djiuser_NOq0TfaIhHxS
Flight distance : 192881 ft
Poland
Any flight tests with the new firmware guys ?
2021-6-16
Skywriter91
Flight distance : 417933 ft
Ukraine
When will be available 5,8Ghz for Ukrainian users?
Why this frequency is available for mini and not for mini 2 ?
2021-6-16
djiuser_LvTCH4xZN3Z7
Flight distance : 254416 ft
How do each of my batteries get updated? Is it done automatically via the drone?
2021-6-16
djiuser_MPVzrFXSMiLi
Flight distance : 73261 ft
Montenegro
Thank you DJI excellent job.Please if you can of course give as sdk  ,upgrade possibility for advanced modes - SAR (Search and Rescue mode - mark lost souls from above and share locations parameters  with social network - waypoint mode of searching) Waypoint mode and planned auto flight and Follow me mode.Thank you for awesome UAV quadrocopter mavic mini 2 with outstanding capabilities .
2021-6-16
aykutaltindag
Flight distance : 27687 ft
Turkey
Thanks for this update, but it is necessary to prevent automatic charging from the remote. In particular, an active tracking system should be activated.
2021-6-16
Dryvise
Flight distance : 10869498 ft
Russia
I wonder how this is implemented, the battery firmware hasn't changed ...
2021-6-16
Mobilehomer
Flight distance : 15054177 ft
Did the update. Only one of my three batteries updated. Reason?
2021-6-16
Keith Tweedie
Flight distance : 642477 ft
The update deals with the battery issue, I assume the battery used in the update will be updated, how will the other two batteries be updated if you have the fly more package.
2021-6-16
Frank Alonso
Flight distance : 743448 ft
MySky Posted at 6-16 02:48
Are you referring to doing this at full resolution?  Because the 360's are stiched together at a lower resolution.
2021-6-16
Frank Alonso
Good news about the compass calibration!  It is a minor inconvenience that I would not mind doing less.
2021-6-16
Sl55kleemann
DAFlys Posted at 6-16 00:04
Same for the -90° & horizon issue due to last update
All new firmware & dji fly update make my mini 2 fly with new bugs...................
Now I have to check horizon before every flight & replace to -90 at every picture when I move a little.
I think to no update this time
2021-6-16
Robert20
Flight distance : 976798 ft
Keith Tweedie Posted at 6-16 10:26
Good question, while updating I even forgot which one of the three batteries was on board of the drone.
2021-6-16
peter_h
Robert20 Posted at 6-16 12:29
Simply shut everything down (aircraft, controller and app), insert a different battery and then start everything up again.  You should see the 'update battery firmware' in the app if it needs updating.
2021-6-16
djiuser_KXn368iMxEQI
Flight distance : 72927 ft
Ottimo aggiornamento firmware installato senza nessun problema.
Le batterie si aggiornano in automatico, basta spegnere il sistema e riaccendere dopo averla cambiata.
Ottimo anche il riconoscimento da parte dello Smart Controller, basta seguire le istruzioni di configurazione che compaiono sullo schermo.
Finalmente un solo Controller per tutta la flotta.
Ottimo lavoro DJI
2021-6-16
Skywriter91
Ukraine
Interesting moment. In settings I found dual chanel, 2,4 and 5,8 band selection, but on signal/noise diagram I still see only 2,4 Ghz scale.
Is this preparation to open 5,8 frequency for Ukraine or just some bug?
2021-6-16
Keith Tweedie
I figured it out , repeat upgrade for each battery
2021-6-16
AceInTheHole
Flight distance : 600016 ft
So I was promted for the update when I was flying today. After the update I went on my first flight. The image being transmitted back to the controller was very cloudy. I was worrying but I just reset the drone and everything worked perfectly.  The FPV mode does seem to work a lot better. I also notice a difference in flight. It does seem to be more stable.  Thanks DJI
2021-6-16
JohnDG
Flight distance : 1018074 ft
Malaysia
Keith Tweedie Posted at 6-16 16:22
Hi,
how did you update the 2 other batteries.
I tried updating by shutting down everything, inserting one of the batteries that wasn't in the drone while updating. Restarted everything and waited for the message I usaually get on the screen. Nothing happened this time.
2021-6-16
DJI Stephen
Super Moderator
Montfrooij Posted at 6-16 00:40
You're welcome!
And likewise!
Hi there Montfrooij. Thank you for the reply and it is always my pleasure. Please fly safe always and have a nice day. .
2021-6-16
Montfrooij
It seems to have improved, although I don't know if that is related to the lack of wind when I was tested.
2021-6-16
Montfrooij
DJI Stephen Posted at 6-16 22:23
Thanks. You too!
2021-6-16
Montfrooij
Sl55kleemann Posted at 6-16 12:20
I tested yesterday with the new update and looking down 90 degrees I found no issues this time. But there was very little wind, so that could also have been the reason.
2021-6-16
DAFlys
Thats a real bummer.
2021-6-16
DAFlys
Montfrooij Posted at 6-16 22:29
I will do the update today as the rain is horrible and then I will spend the rest of the day in the workshop making some pens.
2021-6-16
Robert20
Can we leave now the 3 batteries firmly pressed onto the contacts in the charger hub?
2021-6-17
Montfrooij
DAFlys Posted at 6-16 23:55
Curious if you have the same experience (once you can fly).
2021-6-17
Montfrooij
PS, making pens?
2021-6-17
MySky
Frank Alonso Posted at 6-16 10:26
Yes, like it is done direktly on the SD card on the MA2 or A2S.
2021-6-17
DJI Stephen
Super Moderator
NickLy Posted at 6-16 03:02
Thanks!
Hi there NickLy. You are very much welcome and thank you for the inquiry. As of the moment, we do not have any information with DJI's future updates and with regards to this matter. Kindly please stay tuned to the latest updates by subscribing to DJI official website at www.dji.com or following us on social media ( Facebook: https://www.facebook.com/DJI , Twitter: https://twitter.com/djiglobal , YouTube: https://www.youtube.com/user/djiinnovations ). Thank you.
2021-6-17
12345Next >
