Altitude 13 feet while on the ground
931 4 2015-7-21
Jscgaston
Flight distance : 316772 ft
So my second Inspire is giving me some issues. If I fly anthing more than straight up and straight down between 5-15 feet then when I land the Inspire thinks its still up in the air. When I landed on my last flight ( max height of maybe 100ft ) it thought it was 13feet of the ground and 33ft away when I was standing right behind it. Props won't slow down untill you shut her down. This is its 4th flight, all of them short and pretty low as I was testing out my Tb48's which had dropped 30% while updating. The first two it was off 3ft and 5ft. Then I recalibrated IMU and compass. She flies normally though I think she handles differently than my model A. Feels like she flies more loosely, if that makes sense. A bit less more controlled. No drifting or weird behavior except the altitude thing. I have over 40 flights and lost the first one due to pilot error, meaning I have checked all I can think of. Emailed DJI US support today and am yet to hear back. I am leaving for the islands Friday and will be taking off from a boat often. This makes me nervous about Gps mode while the boat is moving and landing. It's going to want to hold it's cordinates...could be ugly if i forget to switch to Atti. Anyone have this issue? Fixes?
2015-7-21
GB44
Flight distance : 343848 ft
You don't want to be taking off from a boat with the problems your experiencing.
I had similar errors with my first aircraft showing incorrect altitude and it was a defective barometer, requiring replacement.  I guess you should be getting in touch with DJI to discuss how to proceed or your dealer.
2015-7-21
Jscgaston
GB44 Posted at 2015-7-22 06:39
I had similar erro ...
That's exactly what I thought unfortunately.......
2015-7-21
shemp
GB44 Posted at 2015-7-21 17:39
Did you send yours in to replace the barometer?
Thanks
Jeff
2015-10-20
GB44
shemp Posted at 2015-10-20 16:44
Thanks
I Contacted DJI then took it back to my UK Dealer who replaced it with a new one
2015-10-21
