JJB*
Flight distance : 12260774 ft
Hi,
Had a look, your MA2s descended with a speed down of 6 m/s, that in the specs!
VPS height sensor started to see the surface beneath only at 8.1 meter, so after this your MA2s should slow down to zero speed down at 0.5 meter.
See my chart. (btw skip the NoControlDown remarks, shoud not be in there)
But exact at this point you cancelled the landing....btw good action to take over control if you do not trust what you are seeing....
VPS botom sensor should see the surface below bit earlier, but that is ofcourse depending on the texture of the ground.
Try this, hover at 30 meters, full down in sport mode and keep the stick down all the time. See that the drone is slowing down and come to a stop at 0.5 meters. After short moment at 0.5 mtr it will autoland.
PS warning "Remote controller signal weak. Adjust remote controller antennas" already at 750 meters away from HomePoint, flying at 113 meters height. Not that good for a MA2s.
cheers
JJB
