Ronin RS2 usage at high speeds
1339 1 2021-6-23
Pit.Fdz
Mexico
Hi! I was wondering...Is it safe to use my Ronin RS2 at high speeds with the force or strain that wind can sustain on each axis motor?
Obviously, the idea is to use it with Push Mode deactivated. But, for example, at the side of a moving car from the window, at considerable speed, wind force can sustain a considerable pressure on the motors and I wonder if there is a recommended limit to do this before putting an excesive strain on the whole system.
Thanks!
2021-6-23
djiuser_5KYCutmsRsqH
Looks like you never got an answer, I was wondering if you’ve ended up using it the way you described? I do the same with my Ziyhun WeeBill S and it holds up okay, but thinking about ditching the Weebill & my Ronin M for the Rs2
2023-2-19
