I have wanted to fly this field and water tower for a while now and kept putting it off because it is in air space controled by an air force reserve base that does not support LANCC. Finally I put in the request to the FAA, got approval, followed their instructions and called the tower 30 minutes prior to flight and again once I was done.
I filmed with the DJI Air 2s in D-Log at 60FPS (60p). I output three video's one in 24p, one in 30p and one in 60p just to compare what the results look like. Here are the links if you want to check out what the different frame rates look like. The videos are all in 4K, Youtube may take a little while to process them and make the 4K resolution available.
60p original to 24p: 60p original to 30p:
60p original:
Hello there MichaelMuni. Good day and thank you for sharing these interesting videos you have filmed here at DJI Forum. Nicely done and thank you for your support.
Very nice! i personaly dont like to use 24P. I always use 30p or 60p.
What i can see is that you have heavy lens distortion on the top left corner... all the other 3 corners seem fine.
