Occusync 2/3
379 4 2021-6-26
djiuser_jZSX9yOUlmJ5
Flight distance : 5239718 ft
Does anyone know how the firmware/software goes about frequency selection and signal bandwidth (10 or 20mHZ)? Originally I thought that it would automatically select a channel with the least amount of interference, however, after lots of observations, that doesn't appear to be the case.
Also, under the transmission menu, what is the difference between HD and smooth selection?
My equipment is the Air 2s.
2021-6-26
Captain Dangerous
Flight distance : 251762 ft
The HD vs Smooth option just means that the HD will always force your video to be HD and therefore with a bad signal may drop frames and the smooth allows continuous transmission but the quality may drop below HD.
2021-6-26
Captain Dangerous
2021-6-26
Captain Dangerous
Also I am not sure how the auto selection works, but would assume it would avoid congested channels.
2021-6-26
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. With regards to the channel mode, once you set it on manual mode, you have an option to change it manually between 10 or 20mhz. If you are in Auto mode, the drone will automatically select the best available channel in the area where you are flying. Also, the difference between the HD and smooth, HD live feed transmission up to 1080p@30fps while the Smooth 720p@30fps. Hope this helps. Thank you for your support!
2021-6-26
