Over Exposed Footage Phantom 2 Vision Plus 3.0
946 9 2015-7-22
joe
Hello,
I just got a Phantom 2 Vision Plus 3.0 and when I try to shoot outside the footage is super over exposed. I'm shooting auto WB @ 1080P 30FPS with an ISO of 100.   Please help!
Thanks!
2015-7-22
joe
2015-7-22
roy
Double check as there are settings for  sunny, give it a try and test to see if that improves the exposure also check the exposure metering and try average. If those don't do it then look at the exposure compensation and try adjusting. There is even a setting to restore to defaults just in case you get to for out and want to start over. Good luck!
2015-7-23
nrgwise
Try using ISO 400.  The angle of the camera is also important.  A slight shift up or down can produce very different results depending on the available light and angle of approach.
2015-7-24
Large35
nrgwise Posted at 2015-7-25 04:07
Try using ISO 400.  The angle of the camera is also important.  A slight shift up or down can produc ...
I tried using ISO 400 and it didn't help at all.
2015-7-24
Large35
roy@mcscomputer Posted at 2015-7-23 18:07
Double check as there are settings for  sunny, give it a try and test to see if that improves the ex ...
How do you factory reset it?
2015-7-24
Oldman
Set ISO to 100
Set Exposure METERING to AVERAGE
Set EXPOSURE COMPENSATION to -.03
This should give good results in most lighting conditins.
2015-7-28
Large35
Oldman Posted at 2015-7-28 23:41
Set ISO to 100
Thanks I'll try that. I've submitted two tickets to DJI and they haven't responded yet. Grrrrrr!
2015-7-28
Large35
Woooooooooooo Hoooooooooooooooo! I figured out how to factory reset it and it's all good now. Thanks for the help guys!
2015-7-28
daniel_babinski
Brazil
Large35 Posted at 2015-7-28 14:22
Woooooooooooo Hoooooooooooooooo! I figured out how to factory reset it and it's all good now. Thanks ...
can you tell how to do it? Thanks!
2016-2-16
