houston
Flight distance : 21241217 ft
I have noticed this problem a lot when I fly. I have even noticed that when the bird was facing in one direction, it was level. If I pointed the bird in another direction, it would be off by a few degrees. Sometimes worse than others. Point it back to the original direction, it was normal. I have concluded that peter.psilver is correct. Make sure you fire it up on level surface. If not, the gimbal seems to go off level.
Houston |
