Ac power adapter fpv
1297 2 2021-7-2
fans3a9be73c
Flight distance : 780223 ft
Thailand
Can I use the DJI FPV AC Power Adapter with a regular charger?
2021-7-2
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. Can you please confirm what regular charger are you referring to? The DJI FPV AC Power Adapter comes with a specific cable to charge the battery. Connect the AC power adapter to an AC power supply (100-240 V, 50/60 Hz) then attached the Intelligent flight battery to the AC power adapter using the battery charging cable with the battery-powered off. Thank you for you your support!
2021-7-2
fans3a9be73c
Thailand
Need to replace the DJI FPV AC Power Adapter, mine is broken.  Repair takes a month.  Don't want to wait that long or buy a second one from dji
2021-7-2
