Focal Length and Sensor size for Mavic 2 Pro
7849 4 2021-7-3
Joyceanblue
India
Hello, I recently recieved a footage shot with a Mavic 2 Pro, the resolution of the footage is 3840x2160, I was wondering what is the focal length and sensor size, I need this information to camera track the footage.
Thanks
2021-7-3
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. The DJI Mavic 2 Pro has a 1"CMOS sensor with a 28mm focal length. Hope this helps. Thank you for your support!
2021-7-3
Christopher O
DJI Paladin Posted at 2021-7-3 23:54
Is that an equivalent focal length (e.g. the Mavic Air 2's focal length is an actual focal length of 8.70857 because of compensating for its half-inch sensor, but an equivalent focal length of 24 mm), or is the Mavic 2 Pro's actual focal length, 28 mm?
The equivalent of 28 mm with a 1-inch sensor, would be 20.32 mm.
2022-12-27
CloudVisual
Flight distance : 97545420 ft
Christopher O Posted at 12-27 06:18
Focal lengths of cameras with integrated (non removable) lenses are almost always given as a 35mm equivalent.
What's worth adding is that if you shoot in 10bit HQ mode, the focal length changes to roughly 35mm.
2022-12-27
pan054
Christopher O Posted at 2022-12-27 06:18
Hi,
I calibrated my Mavic 2 Pro between alt 5 and 100m in 16 steps and found that a focal length of around 20mm gave me the best results.  Errors of +7% at 5 m (overestimated size on ground) and -5% at 100m (underestimated). About right at 30m altitude in the x-direction (width). Both in Auto and manual camera modes.
2023-2-18
