DJI Susan
Hi CR3, may I know if the vibration happens when you are shooting in other scenarios, e.g. on the ground. If the issue only existed while using it on the helicopter, we may suggest that holding the gimbal to decrease the influence by the vibration source (helicopter). If the vibration comes along with gimbal tilt, you may try to use an external GPS module.
You may try to use a vibration absorber regarding the Z-axis issue, you may try to find one in the third-party accessory market. Thank you. |
