New RSC 2 Firmware Released! (07/06/2021)
4193 18 7-5 23:26
DJI Support
Flight distance : 2408 ft
South Africa
Overview:
  • Date: 2021.07.06
  • Firmware: v01.03.00.00
  • RavenEye Firmware: v01.02.00.20
  • DJI Ronin App iOS: v1.4.9
  • DJI Ronin App Android: v1.4.8
  • User Manual: v1.0
What's New?
  • Added photo capture for Sony α7S III and α7 C cameras using a Multi-Camera Control Cable (USB-C).
  • Added photo capture, video recording, camera settings, autofocus, and focus pull support for Sony α1 and FX3 cameras with supported Sony E mount lenses using a Multi-Camera Control Cable (USB-C). To use autofocus on the Sony α1 and FX3 cameras, press halfway down on the camera control button of the gimbal.
  • Added video recording, camera settings, autofocus, and focus pull support for Sony ZV-1 cameras with supported Zeiss Vario-Sonnar T lenses using a Multi-Camera Control Cable (Micro-USB). To use autofocus on the Sony ZV-1 cameras, press halfway down on the camera control button of the gimbal.
  • Added photo capture, video recording, camera settings, autofocus, and focus pull support for Canon EOS 7D Mark II cameras with supported EF mount lenses using the Multi-Camera Control Cable (Micro-USB). To use autofocus on the Canon EOS 7D Mark II, press halfway down on the camera control button of the gimbal.
  • Added photo capture, video recording, camera settings, autofocus, and focus pull support for Panasonic Lumix S1R cameras with supported L-mount lens using a Multi-Camera Control Cable (USB-C). To use autofocus on the Panasonic Lumix S1R, press halfway down on the camera control button of the gimbal.
  • Added video recording, camera settings, autofocus, and focus pull support for BMPCC 6K Pro cameras with supported EF mount lenses using the Multi-Camera Control Cable (USB-C). To use autofocus on the BMPCC 6K Pro, press halfway down on the camera control button of the gimbal (requires camera firmware v7.3.1).
  • Added photo capture, video recording, camera settings, and autofocus for Leica SL2 and SL2-S cameras with supported L mount lenses using the Multi-Camera Control Cable (USB-C). To use autofocus on the Leica SL2 and SL2-S, press halfway down on the camera control button of the gimbal.
  • Added aperture, ISO, and EV settings for FUJIFILM X-T4 in video recording mode.
  • Added ability to use ActiveTrack without DJI RavenEye Image Transmission System for Panasonic LUMIX S1, S1H, S1R, and S5 when using Multi-Camera Control Cable (USB-C). Requires the latest camera firmware (https://av.jpn.support.panasonic ... ownload/index4.html).
  • Optimized rotational speed when calibrating focus motor.
  • Reduced focus motor noise.
  • Fixed issue: Canon R5 and R6 cameras crashed when camera control command was different from the camera shooting mode.
  • Fixed issue: unable to autofocus with FUJIFILM XT3 and XT4 cameras when in video recording mode.
  • Fixed issue: unable to control shutter with BMPCC 4K, 6K, and 6K Pro cameras when using updated camera firmware v7.3.1.
Notes:
  • Make sure that the DJI Ronin app is the latest version when updating the firmware.
  • Update the firmware using the DJI Ronin app by connecting the DJI RSC 2 via Bluetooth. Do not disconnect the DJI Ronin app and DJI RSC 2 during the update process.
  • Update the firmware for the DJI RavenEye Image Transmission System using the DJI Ronin app by connecting the RavenEye via Wi-Fi. Do not disconnect the DJI Ronin app and DJI RavenEye Image Transmission System during the update process.
  • If DJI RSC 2 has a camera attached and is powered on while updating the firmware, make sure to protect the camera and lens as the motors will power off during the update.
  • If the firmware update fails, restart DJI RSC 2 and retry.
7-5 23:26
Adomolis
Flight distance : 219219 ft
Update seems to be stuck at 0% for me, unfortunately.
7-6 01:28
Gd小猪
Flight distance : 678609 ft
South Africa
Adomolis Posted at 7-6 01:28
Turn off the power and then upgrade
7-6 23:01
espritDJI
Russia
Good afternoon. A question about dji rsc2. I updated the firmware and now on Canon 5DMarkIV, after turning off the recording, the mirror closes and opens again. Previously, the recording simply stopped, the mirror was closed only after switching to sleep mode or turning off the stabilizer. Is it possible to install the previous firmware somehow?
7-10 11:11
hidra
Flight distance : 19583 ft
Indonesia
Added ActiveTrack for Panasonic LUMIX S1, S1H, S1R, and S5 using the Multi-Camera Control Cable (USB-C). Requires the latest camera firmware
Does that mean we don't need raven eye to enable activetrack?
7-11 03:10
x_0
I can confirm that this firmware brings all the X-T4 gimbal control features to the Fujifilm X-S10 as well after updating my X-S10 to V2.00 and connecting it to my RSC 2+Raven Eye via USB-C. Finally, the x-S10 has reached feature parity with its big brother!
7-11 18:45
Art6
Mexico
espritDJI Posted at 7-10 11:11
The same thing happens to me with a 90D,
Were you able to repair it?
7-11 20:35
Art6
Mexico
I updated the firmware and now on Canon 90D, after turning off the recording, the mirror closes and opens again. Previously, the recording simply stopped, the mirror was closed only after switching to sleep mode or turning off the stabilizer.
7-11 20:36
espritDJI
Russia
Art6 Posted at 7-11 20:36
I have the same thing on MarkIV.
7-11 23:58
espritDJI
Russia
Art6 Posted at 7-11 20:35
No, it didn't work out. I'm suffering. I hope DJI will fix this as soon as possible. Even during the video recording, the video recording stops spontaneously sometimes
7-12 00:01
espritDJI
Russia
To lower the firmware level, please follow these steps:
Click on the list in the upper-left corner to go to the "About" page, click on the firmware version, press and hold the firmware version text for 5 seconds in the "Firmware Version" section, and then you can select the version you want to upgrade to.
7-12 02:49
HubertT
Hi, any chances we can get A7C to fully work with Raven Eye and RSC2?
7-12 07:22
fans4f0a70c7
Brazil
Good night, I'm also having the same problem, when I stop a recording it closes the mirror of my canon 5D mark III after the last update, how can we solve it?
7-12 13:52
espritDJI
Russia
fans4f0a70c7 Posted at 7-12 13:52
I wrote above how to roll back the firmware
7-12 20:05
espritDJI
Russia
7-12 20:06
fans4f0a70c7
Brazil
espritDJI Posted at 7-12 20:06
I did this and resolved.  Thanks.  Now I have other problems, activetrack is not working and when I start recording using the ronin rsc 2 rec control it doesn't start recording in the app, and the camera speed, aperture and ISO information doesn't appear in the app. with the N/A information in these fields, can you help me resolve this?
7-14 08:11
Nullantechamber
Is DJI ever going to update the raveneye firmware for nikon z6ii/z7ii?  I have this thing just sitting on a table because none of the features advertised work.
7-19 06:53
Tobias10
Vietnam
If DJI RSC 2 has a camera attached and is powered on while updating the firmware, make sure to protect the camera and lens as the motors ...
https://www.couponupto.com/coupons/make-me-something-special
7-22 01:35
Art6
Mexico
espritDJI Posted at 7-12 02:49
Perfect, thanks
7-23 16:45
