mini 2 battery blinking 3 times
8371 7 2021-7-9
Piekar
Flight distance : 1562605 ft
Hi one of the battery on my mini 2 after charging is blinking all 4 leds three times and not working how to fix this problem ?
Thank you for any help
2021-7-9
AussieDronePilot
Flight distance : 1942792 ft
From page 24 in the user manual https://dl.djicdn.com/downloads/DJI_Mini_2/20210222/DJI_Mini_2_User_Manual_EN.pdf
The very last line in the screenshot, “The four LEDs blink simultaneously to indicate the battery is damaged.”
2021-7-9
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble. Can you please confirm if it does the blinking when inserted into the unit? Or it also shows the blinking issues even you didn't install it and press the power button? Can you please provide us a short video sample showing the issue for better assistance? Please keep us posted. Thank you!
2021-7-9
Piekar
Thank you for email
I unfortunately I can not add video is blinking all 4 leds 3 times on the charging box when connected to power supply.
When is off charge in the unit not showing nothing all 4 leds are blank even when I press status button
When in drone is not working
2021-7-9
djiuser_FykQ4Z5etRuY
South Africa
My one battery does the same, any answers as to why?
2022-2-4
Johnny_J
Sweden
DJI Paladin Posted at 2021-7-9 19:27
Incredible that you need a video to understand what's already written in text.
2022-2-4
djiuser_IQy4Nx7HCm9F
Flight distance : 1678461 ft
Also incredible that the issue seems to not be resolved. I have a battery that also did this fresh out of the box. I checked the voltage with my fluke and the battery is completely dead (~0.2VDC) you can rig a set of jumpers from a sister battery that’s not in the charging hub and place that dead battery in the hub while it’s connected to the other battery and it will charge the battery fine and it’s good or if the cell is beyond repair then it will only charge the host battery. Hope this helps. Also, don’t expect full capacity out of the salvaged battery either, mine has about 12-14 minutes flight time with ideal conditions.
2022-12-22
**Disclaimer** I’m in no way affiliated with dji nor do I recommend this fix for solving your issue. Just some general knowledge that may or may not potentially solve the dead battery issues you’re having. Try at your own risk.
2022-12-22
