Triggering Record button Ronin RS2 with Raven Eye and Canon EOS R
4263 10 2021-7-14
fans0b90d822
Flight distance : 205194 ft
I have an EOS R connected to the Raveneye and the RS2, everything balances correctly and connects to the app, enabling ActiveTrack etc.
But for some reason I cannot get the record button on the gimbal to trigger the recording of the camera.
Has anyone had this experience and know how to solve it?
I've enabled remote control on the camera as well, with no luck.
Have swapped all the USB-C controls on the side of the RS2 with no result either.
I appreciate any ideas.
2021-7-14
dux
Yes, I too had this issue in the last two uses of the combo but with an R5.
I bypassed the RSS / control of the Raveneye and plugged directly back in. (HDMI kept rolling).
Trigger / record button worked as expected once bypassed.
Did this twice. But it was so frustrating I had to start stop with the camera record button.
There seems to be a firmware issue in the Raveneye where it doesn't respond to the trigger.
2021-7-17
DJI Susan
Hi there, may I know if you are able to initiate recording while the camera is not connected to the RavenEye system? Please note that when switched to Photo mode, the camera won't respond to video-capturing commands; when switched to video mode, the camera won't respond to photo-capturing commands.
2021-7-29
fans0b90d822
Hi Susan,
I was able to trigger it by reversing the cable connections, but when you stop recording it goes back to photo mode, which throws the exposure etc. of the camera.
2021-7-30
paoloqbek
Flight distance : 16322 ft
Poland
DJI Susan Posted at 7-29 23:14
My EOS R connected to RSC2, after pushing rec. button on ronin handle for ending video recording, is going switch to photo mode. How to fix this phenomenon?
2021-7-30
DJI Susan
fans0b90d822 Posted at 7-30 01:42
Hi Susan,
Hi there, sorry for the issue. Currently, please downgrade the firmware of the RS 2 to avoid the error.
Method: Click on the list in the upper left corner to enter the "About" page, click on the firmware version, press and hold the text of the firmware version for 5 seconds in the "Firmware version", and then you can choose to downgrade to the previous version.
Our engineers are aware of the issue and will optimize it in the next firmware update. Apologize again for the inconvenience caused, thank you for your understanding.
2021-8-1
DJI Susan
paoloqbek Posted at 7-30 03:47
Hi there, sorry for the issue. Please refer to my reply above, currently, please downgrade the firmware of the RSC 2 to avoid the error.
Sorry again for the inconvenience.
2021-8-1
paoloqbek
Poland
DJI Susan Posted at 8-1 03:12
Hi Susan. Thanks for response. What firmware number should I downgrade for avoid this issue?
2021-8-2
DJI Susan
paoloqbek Posted at 8-2 06:17
You can download the firmware to the previous version v01.02.00.30 to avoid the issue.
2021-8-3
Da-Cidre
Flight distance : 17700 ft
Glad to see this post as I was using it today after upgrading the firmware to 1.4.8 and pressing the record button on the RS2 with my EOS R activates slow motion photo mode
2021-8-4
DJI Susan
Hello there, the new firmware is now available, you can update the firmware now. Release note: https://forum.dji.com/forum.php?mod=viewthread&tid=248176
2021-8-17
