ds9193
Flight distance : 64469 ft
I can try this, although shouldn't GSpro automatically calculate the horizontal speed and minimum capture interval based on the overlap settings you use? The issue is that the app disables two bands after a battery change, they are enabled when the first battery is used but then automatically get disabled. We now make sure to check that the bands are enabled after the battery change, but this shouldn't happen..
Additionally, the elevation information in the exif data also changes after the battery swap, even though the P4M actually flys at the same altitude.. I've attached a screenshot from Agisoft Metashape for illustration..
elevation differences
