Air 2s Crashed itself into a wall
4030 11 2021-7-19
scoobsscoobs
Flight distance : 59203 ft
Hi everyone,
New droner here... Hopefully this is the right forum to ask for help.
I've had the Air 2s a few weeks and really liking it, no problems at all except one.
I was flying over a small stream and under a bridge the other morning when i stopped to change the camera settings, the drone was hovering, then all of a sudden I heard it make a sharp move. Looked up and it was quickly pushing itself to the left. It stopped, then did it again straight into the wall under the bridge.
I wasn't far away from it, probably about 20 meters, at the same level as it.
I had been flying for about 20 mins in the same location before that and everything was fine. I had landed and turned it off momentarily before launching again.
I've uploaded the flight data here: [backcolor=rgba(249, 249, 249, 0.3)]https://app.airdata.com/share/hgKnSB
Although I have a hard time understanding any of it maybe someone could shed some light on what happened.
Thankfully after hitting the wall it bounced down onto a rock below, and I was able to retrieve it. Just needed to change the propellers and it's been fine ever since. But would like to know if I did something wrong/missed something so that it doesn't happen again.
Thanks in advance,
Steven
2021-7-19
DJI Stephen
Hello there Steven. I am sorry to read and to know what happened to your DJI Air 2S. Since there was a crash that happened before and if you feel that on your future flights that the said DJI drone is not working / flyuing properly. It would be best to contact our DJI support team at https://www.dji.com/support . We have a professional team that will do there best to assess the said drone and give out the best resolution for this issue. Again I am sorry for this trouble and please stay safe always.
2021-7-19
DAFlys
It looks like you took off without getting satellite lock first,  5 minutes into the flight the drone switched to atti mode which means you have to keep it stable especially as vision sensors were not available.  You should have seen a lot of alerts on the screen,   they are shown here - https://app.airdata.com/share/hgKnSB/GENERALNotifications
2021-7-19
scoobsscoobs
DAFlys Posted at 7-19 22:51
Thank you very much for your reply - that makes a lot of sense and reading about Atti mode, tracks with what I saw.
Glad it wasn't too bad a crash and now I'm aware of this going forward!
2021-7-20
DAFlys
scoobsscoobs Posted at 7-20 00:15
Always best to have at least 11 sats locked before take off.
2021-7-20
scoobsscoobs
DAFlys Posted at 7-20 00:17
Cool thank you...
I usually do take a little look, think because I'd just been up with it with no problems I stupidly didn't check everything over again for the second take off.
Appreciate the help!
2021-7-20
DAFlys
scoobsscoobs Posted at 7-20 00:34
Cool thank you...
Id say its the number one reason people have issues with their drones.
2021-7-20
FriedChicken_II
Flight distance : 721555 ft
According to AirData:
In 5m 51.2s, someone or something touched your controller stick which gave the drone a full throttle. It released 1.4 seconds later and your drone was at 1.6m/s speed.
And your drone was flying on side ways, with the obstacle hiding there.
I think that's why your drone crashed. Someone did a mistouch on the controller, and unfortunately your drone was facing sideways towards the obstacle. So no obstacle avoidance can be applied before the crash.
2021-7-25
ClassicShooter
Personally I have created a routine when flying, after powering everything on I go through a series of checks like making sure my RTH is set for the location I am flying, getting my FAA Controlled Airspace authorization, and camera settings just to make sure I have given myself plenty of time to locate as many satellites as possible, but even then never take off without the icon turning white (I think it does that after 10 sats).
2021-7-28
djiuser_wy0049LesA6V
Flight distance : 34692 ft
Iran
Hi
I have almost this problem
In 17 june when after 2 hours of last flight i want to start again.
Drone before completely take of automatically go forward and hit itself to tree (drone is in normal mode) and broke two propeller and one motor doesn't work right & the drone haven’t balance
2022-6-20
fansff3d2d52
I also met with this problem. I wanted to take off with Dji’s feature to take off I placed my drone on the flat surface (camera heading away from me)  pressed to take off when suddenly drone headed off to the wall and towards me I stood maybe 2 metres behind it and crushed I didn’t press anything. I’m scared to fly again, is it safe to do it?
2022-7-10
djiuser_NCp3nzvLO6eX
djiuser_wy0049LesA6V Posted at 6-20 11:01
Hi
I’ve heard of similar issues. And the problem there was that the props were not installed properly. Making sure you color code the ones you need to. Having the props in the wrong spots can create some issues for sure.
2022-7-17
