P1: smart oblique and tilt angle setting
4866 6 2021-7-21
Thru The Lens
testing the P1 before using on paid clients.
in menu settings, there is manual ability to set lens tilt angle, from 90 - 45.  My specific question about this feature is when using Smart Oblique setting.  After selecting Smart Oblique, does the mainual tilt angle still need to be set OR does activating Smart Oblique feature "take over" any manual setting and automatically calculates tilt angle?  If this is NOT the case, what tilt angle do you manually set when using Smart Oblique?
All enterprise dealers I called (4 of them) had no clue.  My test flight yesterday, I noticed the tilt angle stayed at nadir entire time and I didn't see the tilt move to oblique during mission.
THANKS in advance!!!
Robert
2021-7-21
djiuser_kMIg5993HklS
Yes when you turn Smart Oblique on will ned to edit the pitch angle that appears below it.
2021-7-21
Craig_Tas
Flight distance : 2998255 ft
If you don't want photos of the legs in your smart oblique capture then you will need to set it to -60
2021-9-29
djiuser_PDOlRPbgmjX2
I believe I read somewhere that a pilot put the gimbal angle to 60 to eliminate the issue.  I fly in a few days and I will test and follow-up
2021-10-20
AerialMD
I think if you set the gimbal to 60 it will eliminate the issue.  I saw this in a post
2021-10-20
arlbo23
With the new updates, the gimbal angle goes from 0 to 45°. How can I avoid taking photos of the legs?
2023-11-29
fans2060b3fb
Malaysia
AerialMD Posted at 2021-10-20 10:01
why my P1 setting is only 0-45 degree while doing oblique mission?
2024-2-6
