Mavic 2 Enterprise Dual Battery Signal Error
1810 10 2021-7-22
KyleHorsfallADK
South Africa
Hi DJI,
I sent my Mavic 2 Enterprise Dual in to DJI repair centre in CHina to get fixed and they did a great job. I am no trying to fly my drone but it is coming up with an error:
"Battery signal error. Please make sure your battery is produced by DJI and check the battery connection."
What does this mean? I have 3 old batteries and 2 new ones I bought form my local DJI reseller. It is showing up with all of them.
Please assist, thanks.
2021-7-22
DJI Paladin
Flight distance : 318 ft
Hi there. Sorry for the trouble. Can you please try to check the firmware of your DJI Mavic 2 Enterprise using the said batteries one at a time and try to update/refresh the firmware using the DJI Assistant 2 software and check if the issue persists? Please keep us posted. Thank you!
2021-7-23
djiuser_kxVzvjeK0Fpe
Saudi Arabia
DJI Paladin Posted at 2021-7-23 20:08
I have the same problem, I have updated the software to the latest version, but the same problem
2022-11-1
DJI Paladin
djiuser_kxVzvjeK0Fpe Posted at 11-1 02:11
Hi, thank you for reaching out. Can you please confirm what drone are you using? In addition, could you please provide us the serial number of the said batter via PM so we check it here on our end? Please keep us posted. Thank you.
2022-11-1
Saudi Arabia
DJI Paladin Posted at 11-1 02:36
Dji mavice 2 pro ( EU )
S / N : 163DFA90018V3K
2022-11-1
Saudi Arabia
2022-11-1
Saudi Arabia
2022-11-1
DJI Paladin
djiuser_kxVzvjeK0Fpe Posted at 11-1 05:38
Thank you for keeping us posted. Can you please try to uninstall and reinstall the app on your mobile device and check if you still have the error message? In addition, please try to discharge the said battery until it goes to 0% and recharges it again then check on the unit if the issue persists. Please keep us posted. Thank you.
2022-11-2
Sibo19
Dear DJI Team,
I seem to have a similar problem. 3 of my batteries are sending the message "Battery signal error. Please make sure your battery is produced by DJI and check the battery connection." when plugged in the drone and connected with the controller. When I try to do a firmware update (both via controller and via PC), the update gets interrupted around 80% and the same error appears on the controller when turned on again.
In this case the drone can not be started.
I discharged one of the batteries to 0% and tried to update the firmware. It did not work.
I also tried to downgrade the firmware, this too did not work.
Can you help me here? Is there anything I can do?
Thank you in advance.
5-10 00:18
Sibo19
Dear DJI Team,
Is there a possibility, that you can help m with this? Can this be resolved in any way?
Thank you in advance!
5-12 23:13
simon peck
Hi Guys
I have a Enterprise 2 drone and it keeps battery error. Ive been using the batteries since I bought the drone. Have updated th firmware and drained the batteries but it keeps saying the same thing "battery error'
Thank you
Regards
Simon
5-19 20:14
