Booradley
Flight distance : 11349537 ft
Oh no! That sucks man.
I cannot avoid power lines in Southern California and am not too technical with power lines however I may be able to provide insight with this.
I have flown my drone, to no avail, quite close to the standard insulated power lines you see in your neighborhood. You know the ones that are not under a great amount of tension and somewhat low to the ground.
The power lines I see being installed in your picture look very similar to a set of lines that caused a crash for me just a few weeks ago. I was no closer than 100 yards but actually estimate that I could have been at least 200 yards away from the set of power lines interfering with the GPS. I calibrated and completed the pre-flight checklist before taking off and had "safe to fly" appearing on the application. When ready in engaged the left stick solely to take off straight up. As soon as I got 1 foot off the ground the drone began drifting. Forward, backward, and side to side. Anything but hovering! I was far enough away from the power lines that I was convinced it had to be something else. I tried just a few more times to see if the app, quad, or controller needed to be reset or recalibrated. Ultimately it had to be the power lines.
They looked somewhat similar to what is appearing in your photo. Strung at a higher elevation than your typical power line, under tension, and somewhat exposed to the elements with coils and/or non-insulated wires. These weren't even the types that you hear buzzing from below, but those are I suspect even worse.
I would exercise a great deal of caution and be ready to counter act drifting because for me, the closer it got to the ground the more it drifted. The first time I landed I was used to just bringing it down once I found a good spot, the sudden drifting caught me off guard. The few attempts after, I was prepared and landed roughly but right side up. It could have been something else, but I have never flown near power lines like those since and haven't had a single issue since that day. |
