DJI Assistant Calibration Movement Error Help
513 1 2021-7-26
jeffbake
Flight distance : 955587 ft
In the year or so that I have owned my Mavic 2 Pro, I have not been able to successfully run through the Calibration procedure. I have tried different displays and resolutions, but no matter how careful I am, I immediately get movement failure messages right from the start of the calibration.I am using DJI Assistant 2 for Mavic v2.0.14
MacBook Pro 16-inch, 2019 version with AMD Radeon Pro 5500M graphics
I also have an external display which is an LG ultraFine 27-inch monitor (I have tried calibration on both monitors and I have also removed the LG monitor but still no luck).
After emailing support, I tried the calibration on another Mac (iMac 27" model) and it worked flawlessly. I wish I had tried that sooner.
2021-7-26
DJI Stephen
Hello there jeffbake. I am sorry for the trouble this has caused before and it is great to know that you have fixed and solved the said issue. In addition, Thank you for sharing these information as well on how you solved he said issue. Again, thank you for your support and fly safe always.
2021-7-26
