25mph gusts gimbal test
693 6 2021-7-30
Bashy
Flight distance : 2354357 ft
Just to show what a gimbal should be like in gusts in excess of 25mph @ 10m height, I took the ac higher for the proper level test to show the horizon, that's fron about 1:40 ish, please not ethe attitude of the ac on the indicator, and the sound of it...
2021-7-30
DAFlys
You should have checked the gutters while you were up there .
2021-7-31
DowntownRDB
Flight distance : 1722 ft
Nice gimbal test.  Thanks for sharing.
2021-7-31
Montfrooij
Flight distance : 2560453 ft
Nice to see!
2021-8-9
Mini2 Flyr
Flight distance : 4347785 ft
Quite amazing what this little guy can do.
2021-8-9
djiuser_nO2RdSW5BSUg
Flight distance : 80646017 ft
Poland
The gyro indicator does not tilt as if there is a wind of 25mph.
2021-8-9
Bashy
djiuser_nO2RdSW5BSUg Posted at 8-9 21:57
Wow, never thought I would be called a liar with video that clearly shows the foliage giving it somenot to mention the anemometer giving it large and that was at 60fps and I do think the attitude indicator
shows that its quite windy, more so when I turned around 1:55 and face into the wind and again for a
while from around 2:24, noticed I said gusts, which means on and off at 25mph, not actual, average or
constant wind speed.
I can't remember the exact time of day, but looking at the bungalow shadow at 0:46, the time is somewhere
between 1 and 2pm. Now that the time is established and that my anemometer is at between 9m and 10m in
height although certainly it closer to 9m high, and we already know that the wind speed is actually faster the
higher up we go as there are no structures to impede its travel, so when i said 25mph gusts, i was being
conservative so as not to exaggerate (i hate that) but at the time of flight i saw that the gusts were around the
25mph mark at 9/10m high.
Please kindly take a look at the graph from the day in question, i will leave that with you, good day!
2021-8-10
