Sony A6400 with Raveneye blackscreens when pressing record
4847 23 2021-7-31
SerPip
Hi all,
Hoping I'll be able to get some help here,
I have a Sony A6400 with a DJI RS2 and Raveneye, all on the latest firmware
I've plugged the USB-C to Sony Multi from the RS2's top port to the camera
I've got my micro HDMI out, into the HDMI on the Raveneye
I've got a USB-C to USB-C from the bottom of the Raveneye (the side without the HDMI port) into the RS2's bottom port
The problem I've got is that when I try to press the record button from either the RS2 or the Raveneye app, the screen goes black and activetrack stops working.
I was hoping I could get some help fixing this as its basically usable for me at the moment
Thanks
2021-7-31
shehan
Japan
I too have the same problem, as soon as I press the record button it goes black. I really hope there is a solution to this.
2021-7-31
DJI-RS PM 铁匠
Hello, you can turn off the HDMI display in the camera, so there won't be the problem you said
2021-8-1
DJI Susan
Hi there, please refer to the answer on 3#, try to turn off the HDMI display in the camera. Please keep us updated if the issue persists, a video of the issue would be greatly appreciated.
2021-8-2
DJI Susan
shehan Posted at 7-31 19:15
Hi Shehan, please refer to the solution above and keep us updated.
2021-8-2
SerPip
DJI Susan Posted at 8-2 00:32
Hi
I have done as instructed however no difference,
Below you can see the setting i toggled
I also took a video to show the problem however cant upload as an attachment on this forum as it only accepts pictures. Where should I upload the video.
2021-8-2
shehan
Japan
Hi
Thank you for your reply.
I also tried as instructed but still, the problem is there. I have attached several pictures so you can better understand them.
2021-8-2
SerPip
shehan Posted at 8-2 18:47
Hi
I should note that when I press record, my camera screen turns back on, it sounds like you're facing a different issue Shehan, I'd suggest making a new thread about it to get more specialised help for your problem.
2021-8-3
SerPip
Just to be clear on my problem
Images below show my setup.
Before I press record, my camera screen is black, I can see my cameras output on the gimbal and raveneye, activetrack works
When I press record on the gimbal, camera, pr raveneye app, my phone and gimbal screens go black and my camera screen turns back on
2021-8-3
SerPip
SerPip Posted at 8-3 03:15
[Image]
Ive made some progress!
I disabled the proxy recording setting and I now manage to keep raveneye connected when pressing record!
However when I press record, now my cameras screen turns off... so we're getting closer.
P.s. shehan might be worth checking your proxy setting too?
2021-8-3
shehan
Japan
thank you SerPip , I already have my proxy recording off.  Thank you anyways. Hope we can solve this.
also, I created a new thread, I'll update you if there's anything new.
2021-8-3
DJI Susan
Hi there, could you please provide a clear picture of the way you connected the camera, gimbal, and RavenEye (as the second picture you posted on 9#) for further confirmation? Thank you very much.
2021-8-3
DJI Susan
Hi
Hi there, please use the Sony Multi cable instead of the Micro USB for the connection. See if that solves the problem. 1.png
2021-8-4
SerPip
DJI Susan Posted at 8-3 23:55
Of course, hopefully this is clear
2021-8-4
DJI Susan
SerPip Posted at 8-4 00:42
Hi, just to clarify again, the Sony multi cable has a longer plug. In your case, please try to restore the camera to factory settings, and please power on the gimbal, then the camera.
If the issue persists, please provide a video of the case to us. You can upload the video to Dropbox/Google Drive, or send it via email to us at support@dji.com. Thank you very much.
2021-8-4
SerPip
DJI Susan Posted at 8-4 01:42
If the issue persists, please provide a video of the case to us. You can upload the video to Dropbox/Google Drive, or send it via email to us at . Thank you very much.
[view_image]
Yep, using the sony multi cable!
I restored to factory settings and am sharing this link to a video which details the problem further.
https://drive.google.com/file/d/1g_-cKERmvYrssW8CWGwyTzgd0JDxEYmH/view?usp=sharing
2021-8-4
shehan
Japan
Hi SerPip
I got my Raveneye and active tracking working when I change to Sony multi cable,  But I also face the same problem as you, the camera screen goes black when the record button is preesed. I hope there is a solution for it .
as a side note since I use my iphone to see what the camera see, for me even if the camera screen goes black it's still manageable because I prefer the big screen of my phone compare to the screen
in a6400.
2021-8-4
DJI Susan
SerPip Posted at 8-4 04:30
I appreciate your cooperation. I will forward the case to our engineers for further confirmation.
At the same time, please try to set the resolution to 1080P and check if it works at this settings.
2021-8-5
DJI Susan
shehan Posted at 8-4 06:00
Hi SerPip
Hi, thank you for getting back, I am confirming SerPip's case with our engineers and will keep you all updated once I hear back from them.
You may also try in 1080P resolution to see if all is working well.
2021-8-5
SerPip
DJI Susan Posted at 8-5 01:03
Hi, I just wanted to confirm the screen remains on (as expected) while in 1080p mode, but not in 4k mode. I still would like to get this working in 4k mode as its the primary quality I record in.
2021-8-5
DJI Susan
SerPip Posted at 8-5 07:19
Hi there, after confirming the case, we are sorry to tell you that since the camera does not support HDMI output in 4K resolution recording,  RavenEye gets a black screen in 4K recording. You may need to use 1080P in this situation. Sorry for any inconvenience caused, hope your understanding.
2021-8-7
SerPip
DJI Susan Posted at 8-7 01:48
Just to be clear, I can get raveneye to work in 4k, but not to keep the camera screen on at the same time (raveneye gimbal and app screen working, camera screen not showing picture but showing level, focus etc). It isn't the end of the world, because I can still use active track via my phone or gimbal screen.
It may be worth noting these in the compatibility docs somewhere?
2021-8-7
DJI Susan
SerPip Posted at 8-7 07:43
Yes, I have mentioned this to our engineers, thank you for bringing this to our attention, sorry again for the inconvenience. If there is anything further I can help with, please feel free to let me know, I will do my best to help.
2021-8-8
fansffb38a94
Any update on this?? I recently bought the rs3 pro combo and I have the Sony a6400 & im having this same problem! Is there a fix?
2022-11-25
