Will Gimbal Roll to Horizontal and Provide Stabilization?
1619 3 2021-8-2
rkruz3
Flight distance : 204049 ft
Will the gimbal rotate the camera 16:9 image orientation if I roll the camera from straight up or 0 degrees and will the camera maintain orientation as I move the camera to a 90 degree or horizontal position  (arm straight out).    While it is held straight out or horizontal will the camera still provide stabilization?
The attached graphic i hope will help explain my question.
I've done a lot of searching but can't find an answer to this.
Thank you
2021-8-2
Curt1591
Thailand
There are 3 modes, Tilt Lock, Follow and FPV, the latter will allow the gimbal to rotate from landscape to portrait. Follow will keep the gimbal in landscape and tilt locl will hold horizon.
2021-8-2
DJI Stephen
Hello there rkruz3. Good day and thank you for reaching out. As posted above the DJI Osmo Pocket has Three ( 3 )  modes ( Tilt Lock, Follow and FPV ). In Follow Mode the pan and tilt axes follow. In Tilt Locked Mode only the pan axis follows. In FPV mode the pan, tilt and roll axes follow. Thank you.
2021-8-2
rkruz3
I was getting confusing and conflicting info regarding the maximum gimbal Roll of the Pocket so I purchased one.   Some were right, the maximum Roll is only 45 degrees no matter the mode the camera is in (some suggested different modes would make a difference).  Here is a link to video of the maximum roll Pocket Roll Limit.
Whats interesting is that there is no mechanical stop until 90 degrees Roll, yet the camera stops and flips from landscape to portrait orientation at 45 degrees.
So ive proven that I cannot use the camera as it will only stabilized up to a 45 degree roll......far far short of what I need for my application.
2021-8-4
