steamship
Flight distance : 229180 ft
Russia
fans5fad8194 Posted at 8-2 14:07
I agree with the logic to t/o in N. As it was for me, For many the M2 may be their first or second drone. Call me stupid but if the app says I'm in C and the switch is set to C it would not be on the top of my list to suspect that the app was lying to me.
Totally agree with you about the physical switch setting and the app display. The software can detect the position of the physical switch, yet it puts the drone into N mode for takeoff. If that's the case, then a few lines of code added to the the Takeoff procedure could solve this confusion. Have the software change the app display to 'Normal' at takeoff, then once the takeoff has succeeded and it's in a hover, check the switch position and place the drone back into that mode (C,N or S) and update the app display with that mode.
If it can change the flight mode to N for takeoff, then the ability to change the flight mode (irrespective of switch position) is already there in the software, and all they need to do is implement it as above. As CemAygun said, it's an easy fix so DJI won't do it. |
