DJI FPV V2 Goggles LCD displays green lines
3634 5 2021-8-13
Random Snake
Flight distance : 15653 ft
Hey All,
I was performing an update last night on my v2 goggles and after the update the left scren started to show some pretty disruptive visual lines.
Now I had been seeing some green shadows since the last 2 flights but thats about 2-3 months due to it being winter here, and I figured light was coming into the goggles from the bottom creating shadows. At the time I didnt think anything of it.
After said update the screen went full matrix and seems to be in a pretty bad way. The screen doesnt appear to be frozen when connected to the drone or in the menu but the left screen is basically unsuable at this point.
Im expecting this to be a warranty job, but before I go down that path I wanted to see if anyone else had seen this and knows of a fix or if its just better to follow up with DJI?
Thanks,
Ben
Left Screen
Left Screen
Right Screen
Right Screen
2021-8-13
DJI Paladin
Flight distance : 318 ft
Hi there. We're sorry for the unpleasant experience. In this kind of situation, I'm afraid that you may consider sending the unit in for a proper diagnosis. You can contact our support team to start up a ticket at https://www.dji.com/support. Thank you for your understanding and support!
2021-8-14
Random Snake
Thanks ill do just that.
For information on anyone else finding this post, I decided to put the air unit in the air to test if I lost connectivity.
No loss of connectivity or RTH kicked in but the goggles started disconnecting and going to a black screen. The goggles then eventually went to a permanent black screen (backlit, but no images).
The drone didnt get taken too high so it was easy to land with direct visual line of sight as all controls continued to work.
Green lines (not burning the screen) seems to be an indication that the goggles might be close to failing.
Thanks,
Ben
2021-8-14
djiuser_foVkTrOJXd35
Had this happen straight out of the box. Did you get a fix?
2022-4-29
ro_flyer
Flight distance : 7557283 ft
Brazil
great views!
2022-5-12
djiuser_bwGXP5w1XElC
Random Snake Posted at 2021-8-14 02:02
Hey been.. same issue.. contact me so we can talk?. Were they ever fixed?
2023-1-5
