Dji N3 ag problem
2550 1 2021-8-16
Thanu al ibnu
Flight distance : 417270 ft
Indonesia
hello, my dji n3 ag died when connecting to dji assistant2, i saw that the flight controller had no lights on, the pmu only flashed a solid red led, I think it's a software or hardware malfunction, what should i do...
2021-8-16
DJI Susan
Hi Thanu, please check if the power supply is normal, since PMU is solid red, you may need to check and make sure that the power supply is the direct-current power supply within 3S -12 S, check if the positive and negative wires are connected correctly. Thank you.
2021-8-18
