Mini2 is there any way to perform firmware refresh?
6692 26 2021-8-23
Denndb
Flight distance : 914688 ft
Croatia
Hello,
I have DJI MINI2 and I would like to perform firmware refresh (like for instance it was possible with my previous mavic mini 1).
It's not possible to do it via DJI Assistant, so is there any way I can do that?
Thanks,
Denis
2021-8-23
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. Unfortunately, we cannot perform a firmware refresh using the DJI Assistant 2 for DJI Mini 2 as of the moment. Can you please confirm what issue did you experience? Please keep us posted. Thank you!
2021-8-23
MBSL500
Post deleted...see below
2021-8-23
MBSL500
Open "Program Files x86" in Windows.
Open "DJI Assistant".
Open "Default settings.
Change "Upgrade Enable" from 0 to 1.
[support]
list=wm161
[wm161]
upgrade_enable=1
Right click DJI Products folder and allow Full Control in the Security tab.
Open DJI Fly...wait a few second and then you will magically see a a list of former firmware updates available.
Flash back to an earlier firmware version if you want.
Done
The next time you open the Fly App it will then prompt you that a newer (newest) firmware version is available.
Install the current firmware version if you'd like.
2021-8-23
MBSL500
DJI Paladin Posted at 8-23 05:23
Unfortunately YOU cannot.....but fortunately HE can..
And I just explained to him how to do it.
And now you know how to do it too.
I'm sure you'll be more than happy to explain the very simple process the next time a customer asks the question.
2021-8-23
hunterws
Flight distance : 382536 ft
Well said MBSL500.
Will there be any conflict if we revert, since the last update updated our controller & batts?
2021-8-23
MBSL500
hunterws Posted at 8-23 08:32
Well said MBSL500.
I can't be certain.
However I flashed back and have had no issues.
2021-8-23
DJI Paladin
MBSL500 Posted at 8-23 05:43
Thank you for your response. We really appreciate you for sharing the steps on how to modify the said software and perform the firmware refresh. We will coordinate this with our designated team for further clarification. Thank you for your valued support!
2021-8-24
The Real Jimbo
Flight distance : 84551 ft
MBSL500 Posted at 8-23 05:40
Worked great, thanks for the info!
2021-8-24
Flycaster
DJI Paladin Posted at 8-24 03:18
Now there going to "fix" that "issue", so it won't be able to be done by the user....
2021-8-24
DowntownRDB
Flight distance : 1722 ft
Open "rogram Files x86" in Windows.
Works great.    Thanks for sharing.
2021-8-24
MBSL500
Flycaster Posted at 8-24 05:27
You can count on that happening.
2021-8-24
hunterws
MBSL500 Posted at 8-24 05:38
I am lost here.  I get to Win86, and the folder, but there are no general preferences to choose.
2021-8-24
Mobilehomer
Flight distance : 18150351 ft
hunterws Posted at 8-24 10:01
I am lost here.  I get to Win86, and the folder, but there are no general preferences to choose.[view_image]
It's in the DJI engine folder. Even before you try to change it, change the properties as instructed. Then change the file and save,
GAVINHR has a video walkthrough if you need it.
2021-8-24
hunterws
Well, he walks people through reverting the app on their device, whereas you instruct how to roll back the aircraft hooked up to assistant, correct?
I would guess both things would need to be done.
Really too bad the company has thrown this wrench in an otherwise good product.  I'm about fed up.
2021-8-24
hunterws
Mobilehomer Posted at 8-24 10:15
There is no file to change, even if security properties are allowed.
I have no option listed as 'upgrade enable'  in the stated folder.  (zero search results for "upgrade")
2021-8-24
Mobilehomer
hunterws Posted at 8-24 11:10
Try this video -
2021-8-24
hunterws
I just uninstalled all DJI remnants off my tablet and installed 1.4.4 ... now I'll watch this video, thank you.
2021-8-24
hunterws
ok, I'm not crazy, I do not have the defaultsettings (now I see what I missed, the activate/deactivate step by step) ...?
reinstalling assitant
ok, I reverted the app and will try that.
2021-8-24
Mobilehomer
hunterws Posted at 8-24 12:06
[view_image]reinstalling assitant
Read reply #14. If your reinstalling Assistant 2 doesn't work, maybe I can send you the file.
2021-8-24
Bashy
Flight distance : 2354357 ft
Has to be the Mavic version too doesn't it?
2021-8-24
dji_MODDER
Flight distance : 73209 ft
get that assistant2 as fast as possible then!!
2021-8-25
fanse0f68750
Flight distance : 239672 ft
Flycaster Posted at 2021-8-24 05:27
I would bet money on that
2022-9-6
fanse0f68750
Since all that stuff was in the default file already, makes you wonder why it was all set to "0". why put the code for it in there if they dont want you to use it?
2022-9-6
fanse0f68750
hunterws Posted at 2021-8-24 11:10
I think the directions in the video only apply to the DJI assistant 2 consumer drone version
2022-9-6
djiuser_6qWEeBcbqwEE
MBSL500 Posted at 2021-8-23 05:43
I can confirm the directions just given will work " Provided you run as Administrator "
I changed the INF file to ( 1 )  and it updated
2022-9-6
