Switching Tablets & Dji Pilot App Settings
965 3 2015-7-26
windasm
I've switched from a Samsung Tab S to a Ipad Air 2 today. Does anybody know what all data that doesn't get stored on the drone and controller? It seems vps is turned off on a new install of Dji Pilot. Custom joystick config must be installed on the controller because it still worked the same. The camera went back to the default settings and I was expecting that. Is there anything else I should be aware of? Thanks
2015-7-26
PhantomAtAK
Seems like verifying Failsafe altitude and maximum height are critical prior to first flight.  Also make sure to verify you have the "return to home" or "land where it is" selected to the config you prefer.  Enable multi flight mode if you use "atti".
2015-7-26
windasm
PhantomAtAK Posted at 2015-7-27 08:36
Seems like verifying Failsafe altitude and maximum height are critical prior to first flight.  Also  ...
Thanks!
I would have forgotten to check the Failsafe altitude if you hadn't a mentioned it.
2015-8-3
PhantomAtAK
windasm Posted at 2015-8-4 09:10
Thanks!
I'm here all week.  Glad to help.
2015-8-3
