JJB*
Flight distance : 12401030 ft
Hi John,
Typical VPS height error wich made your day... !
If the botton sensor is measuring 0.5 (or approx 0.5) meter height (false or true reading) AND 100% stick down than a forcelanding is initated. (see my chart)
The only way to cancel this is to input stick UP for short moment!
In your log 2x a forcelanding, second time you did not had a RC stick UP so the forcelanding was not cancelled.
Sensor can be dirty or wet (fog or high humidity) to get a false reading.
Large chart : see the green bottom line indicating VPS height is active. Top part, see the VPS height value...(so almost all flight is was false reading/indicating)
cheers
JJB |
