FCC and CE again no doubt
1189 6 2021-8-24
NedUK
Flight distance : 555262 ft
Im a little out of the new products and not had to worry about this since my first Mavic Air.
does the UK version of the new 2s use a weaker signal system like the old air did?
If I was to buy an Air 2s in the states and bring it home would I have the better system?
Thanks in advance
2021-8-24
Geebax
The aircraft chooses one of 3 possible radio propagation levels depending upon what country it is used in. The choice is automatic, detected by the GPS receiver.
2021-8-24
DJI Stephen
Hello there NedUK. Good day and thank you for reaching out. Due to local policy and regulation restrictions, the 5.8 GHz frequency band is currently banned in certain countries, including but not limited to Japan, Russia, Israel, Ukraine, and Kazakhstan. Please use the 2.4 GHz frequency band when operating in these locations. Always check local rules and regulations before use, as they may change over time. In addition the maximum flight range specification is a proxy for radio link strength and resilience, not aircraft battery capability. It only refers to the maximum, one-way flight distance. Data was measured in an open environment without interference. Please pay attention to the return prompt on the DJI Fly app during actual flight. Refer to the following applicable standard in different countries and regions:
FCC: United States, Australia, Canada, Hong Kong, Taiwan, Chile, Colombia, Puerto Rico, and other regions;
CE: UK, Russia, France, Germany, Portugal, Spain, Switzerland, Macau, New Zealand, UAE, and other regions;
Thank you.
2021-8-24
DAFlys
If you buy in the USA you may have issues with the warranty though.  Some people had to send theirs back via the USA for replacement/repair.
2021-8-24
Huginn Kenningar
Flight distance : 49635259 ft
The drone is the same worldwide, FCC/CE modes are selected by software but the hardware is the same. If you buy the drone in EEUU and use it in UK, it will work on CE because it chooses the power output depending on your location in the globe.
If you intend to fly VLOS the CE power output is enough (500m is nothing), but if you want more stability (obstacles in the middle, congested 2.4Ghz areas) and long range capabilities there's a permanent FCC hack out there that it's actually the best accessory you can purchase for your drone apart from the official sunhood for the remote controller.
2021-8-25
DowntownRDB
Flight distance : 1722 ft
Check out the FCC boost article here.  Interesting read.
2021-8-25
hallmark007
Flight distance : 10017858 ft
No, simple answer . We’re forever bound by rules..
2021-8-25
