Switching from FPV Drone to Air Unit
2754 7 2021-8-25
djiuser_ABfOIjurHuE7
South Africa
After I switched to the Air Unit and reverted to the DJI drone my status says that the controller and goggles are not connected - cannot fly the drone. I had to rebind the aircraft, controller and goggles. Is this the only way to use both the drone and Air Unit? I tried manually switching the goggles off and this did not help. Please help? I have the latest firmware.
2021-8-25
CoreyB10
Flight distance : 1665023 ft
Yep. Everytime you switch between Air Unit and back to FPV Drone, you have to re-bind. Pain in the ass but the only way to do it.
2021-8-25
South Africa
CoreyB10 Posted at 8-25 23:39
Thank you CoreyB10. I was going insane trying to switch between devices until I did rebind. I hope that future FW updates will make this a lot easier.
2021-8-25
CoreyB10
djiuser_ABfOIjurHuE7 Posted at 8-25 23:53
The thing is is that it's 2 different protocols. I don't think that DJI will release a FW that allows for seamless switching between the 2. I managed to bag a 2nd set of V2's at a good price for my traditional fpv kwads but not everyone is in a position to do this. I fly almost every day so I get the benefit from doing this.
2021-8-26
SgtRay
Flight distance : 14860804 ft
CoreyB10 Posted at 8-26 00:05
It's not just a different version thing. I have 2 air units and the FPV drone and I have to do it for all 3 when using the one set of version 2 goggles..
2021-8-26
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. It is required to rebind or relink your controller and Goggles if you switch between your DJI FPV drone and your DJI Air Unit. Please don't hesitate to reach us if you have other inquiries. Thank you!
2021-8-26
South Africa
DJI Paladin Posted at 8-26 18:47
Thanks for confirming that. This info should be in the firmware release notes - will help a lot of DJI FPV drone and Air Unit users.
2021-8-27
DJI Paladin
djiuser_ABfOIjurHuE7 Posted at 8-27 06:38
I will take this as a suggestion of yours and will forward it to our designated team. Thank you for your valued support!
2021-8-28
