Balancing Ronin SC with Sony RX100 VII
1716 8 2021-8-26
Pasqualito
Flight distance : 19872 ft
Although its says that this camera could be compatible with the Ronin SC, the Sony will not be balanced correctly.
Ofcourse the Sony is a small (and light) camera with a fixed zoom lens in, so the weight will change (middlepoint) when you zoom in or out with the camera, even in de normal position of the lens its not working.
Was anybody succesful and did you have to use counterweights for this (to) light camera??
2021-8-26
Pasqualito
2021-8-26
DJI Tony
Pasqualito Posted at 8-26 11:36
Hi, there. We're sorry to hear about your experience. Could you film a video when this issue happens so I can see more details? Thanks for your support.
2021-8-26
djiuser_hfhQImP4qdIJ
Flight distance : 1580545 ft
I have the same issue. The camera is too light to balance at all.  Not sure what to do.
2022-9-15
DJI_CMac_User
Were you ever able to find a resolution to this issue?  I bought one of these units yesterday specifically for this camera and I can't even come close to balancing because of its light weight.  I would love to know what the fix is ASAP before I return this for a refund (I'm not buying a new camera).
2022-9-15
DJI Susan
DJI_CMac_User Posted at 9-15 08:39
Hi there, may I know the camera and lens you are using for further confirmation?
You may try to use a counterweight and see if it helps to get the camera balanced.
2022-9-16
DJI Susan
djiuser_hfhQImP4qdIJ Posted at 9-15 08:34
Hi there, please also tell me the camera and lens you are using for further confirmation.
2022-9-16
TrinityG
DJI Susan Posted at 2022-9-16 05:26
Hi Susan. I've seen you ask this question before but the make an model of the camera is in the subject heading of this thread (Sony RX100 VII). I have the same camera and the same DJI Ronin SC.
The camera has an integrated lens (not removable).
As mentioned by previous users, although the DJI compatibility guide for this device states that this particular Sony camera is compatible with it, it is still impossible to balance due to its light weight. I've tried all possible configurations and am never able to pass the balance test.
I can provide screenshots if needed.
2023-10-30
DJI Wanda
TrinityG Posted at 10-30 12:19
Hello, there. Sorry for the inconvenience. To better help you, would you please record a video about the balance status for us?
2023-10-31
