TB47
1284 3 2015-7-27
stevejg16
Flight distance : 29001916 ft
My TB47 will not charge completely. I have cycled it down to 6% and tried again, same thing.
It charges to 3 lights then starts a single blink with one light flashing green. Put it back into the Inspire, shows
76% charge. Works fine, brought it back down to 8%, tried recharging and the same thing happened.
Any ideas?
Thanks in advance
2015-7-27
mtnmaddman
Have you upgraded the battery also check in your app and see if your battery cell levels are balanced, if they are, and you have upgraded the batteries firmware then take top off of battery, unplug the plug wait 5 min and reassemble. If you take the top off then look at this. http://forum.dji.com/thread-23697-1-1.html
also  http://forum.dji.com/thread-24403-1-1.html
2015-7-27
houston
Flight distance : 21241217 ft
Put it back in your inspire, fire it up, wait till it gets to 5% or lower. Then try and charge it.
2015-7-27
gwulf
houston Posted at 2015-7-28 07:38
Had the same problem once and did as houston suggests. I even let the battery switched on in the I1 until it switched off itself. After that I was able to load the battery up to 100% again. It had several charge/discharge cycles since then without any problems.
2015-7-28
