Remote controller shuts off during flight
3536 5 2021-8-29
OscarFrederic
Austria
Hi there,
I have an issue with my remote controller. During the last two flights, the remote controller just shut off after two minutes of flight time. On both flights I made sure that the remote controller had full battery. I can shut it on again, but it takes its time and I was always close to the drone. But I am not sure if can connect to the drone when I am further away. It really concerns me and I dont kow what I can do against it. I obviously have all the newest updates installed. Anyone else with the same issue?
2021-8-29
DowntownRDB
Flight distance : 1722 ft
I've never had that issue, but based on all your firmware being updated and remote control having a full charge it appears the issue is hardware related.
2021-8-29
ABeardedItalian
Flight distance : 1063107 ft
How old is the controller, how well does it hold a charge? When my controller was dying it would show all lights solid at the start of my flight, 5 minutes in I would have a low battery warning and only one light would be left flashing on the remote. I would turn the controller off and on again and it would say it had full battery even though it just yelled at me for low battery. It's a design flaw that DJI does not let us disable the part that charges the phone while connected. In my case, when the phone was plugged in to the controller the draw was enough to drop the voltage and cause a low battery alarm, but without the phone connected and no load on the battery it reported the correct voltage.
2021-8-29
DJI Stephen
Hello there OscarFrederic. I am sorry for the trouble this has caused and thank you for reaching out. Since this issue is happening on your DJI Mavic Mini remote controller. I would recommend for you to contact our DJI Support Team at https://www.dji.com/support?site=brandsite&from=nav for further assistance with regards to this issue. We will do there best to help you and give out the best resolution for the said issue. Again, I am sorry and thank you.
2021-8-29
djiuser_ZvoBxgzBMRAu
Hi mate, has it been resolved. I think I have the same problem
2-27 12:14
DJI Tony
djiuser_ZvoBxgzBMRAu Posted at 2-27 12:14
Hello there. Sorry about the trouble. I'm afraid you need to send the units back to DJI for diagnosis. You can submit a Repair Request on the DJI website or use this link: https://repair.dji.com/. The warranty can be applied depending on the assessment's outcome, including your unit's warranty period. We appreciate your patience. Have a great day ahead.
2-27 21:36
