jmb63
Flight distance : 7009439 ft
Easy enough...Just swap the OEM props and try again. When you are that close to the ground the optical sensors on the bottom, which can't be shut-off, are going to be affecting the positioning ( thinking it's landing ) and not let it go down. Also, there is a lot of prop effect at those levels which can cause weird turbulence. |
