DJI Wanda
hamid39 Posted at 10-8 20:17
Hi everyone,
I need to calculate spectral radiance and irradiance separately for each band of phantom 4 multispectral. Currently, I am able to calibrate the images using a reference panel and get the reflectance image (which seems to be reasonable). But when I use the light sensor data, the values I get do not make any sense. For example, in the image of a standard panel, I got 0.26 for blue, 0.20 for green, 0.15 for red, 0.11 for red edge, and 0.12 for nir bands, while I was expecting to get 0.26 for all bands since the panel is standard fixed 0.26 for all bands. So I need to get radiance and irradiance separately to see what the problem is. In the image processing guide of the DJI for phantom 4 they have explained how to calculate NDVI, but no mention on how we can get radiance and irradiance for each band- they have mentioned similar notations but it doesn't work as I mentioned above. Any help is highly appreciated.
Hello, there. Sorry for the late response. The ISO value captured by the light sensor of Phantom 4 Multispectral varies from each band, utilizing which to directly output the reflectivity is inaccessible. The consequent value calculated will not render users a tenable reference. If you want to get the reflectivity of each band, we would recommend you use reflect panel, refer to the procedure of radiometric calibration. That is, calculate the reflectivity by using the DN value of photos. |
